Mon, Jan 6, 7:57 PM CST
Forum Moderators: Staff
Subject: INJect Morph and Auto-Load that Morph
corinthianscori ( ) posted Sat, 25 January 2014 at 11:06 PM · edited Tue, 10 December 2024 at 4:47 AM
No matter what I try, all I can get an INJection to do is inject the custom morph into Victoria 4.2; the injected custom morph does not auto-apply once the morph has been loaded.
HOW can I force Poser 6-9 to auto-load a custom morph once that morph is injected into V4.2? The morph applies just fine once the injected dial is spun.
Note: custom morph is full body morph that uses no proprietary morph packs.
I own: Poser 6,8,9
syrINJ
Injection Pose Builder
Injection Magic
Poser File Editor
Poser Tool Box
Morph Manager
PoserWriter Premium
etc.(and a bunch of other stuff)
3dstories ( ) posted Mon, 27 January 2014 at 10:39 AM
I can't help, but I'd like to know the answer, too.
sixus1 ( ) posted Thu, 30 January 2014 at 12:04 PM
I don't know how you are making your INJ morphs, I always do mine by hand.  Underneath the name of the morph there is a line that needs to be set to '1'
valueParm PBMCC_01
name Fireball
initValue 1
hidden 0
If it is a linked up Full Body Morph, then set it on there only. If it isn't linked up to a dial on the Body, then do it for whatever body parts you want it applied to.
--Rebekah--
structure ( ) posted Sun, 09 February 2014 at 8:26 AM
Forum Coordinator
Quote - I don't know how you are making your INJ morphs, I always do mine by hand.  Underneath the name of the morph there is a line that needs to be set to '1'
valueParm PBMCC_01
name Fireball
initValue 1
hidden 0
--Rebekah--
make sure this is set too
            initValue 1
            hidden 0
            enabled 1
            forceLimits 1
            min -1
            max 1
            trackingScale 0.02
            keys
                static 0
                k 0  1    <<<<-------------
Locked Out
