Forum Moderators: Staff
I don't know how you are making your INJ morphs, I always do mine by hand. Underneath the name of the morph there is a line that needs to be set to '1'
valueParm PBMCC_01
name Fireball
initValue 1
hidden 0
If it is a linked up Full Body Morph, then set it on there only. If it isn't linked up to a dial on the Body, then do it for whatever body parts you want it applied to.
--Rebekah--
Quote - I don't know how you are making your INJ morphs, I always do mine by hand. Underneath the name of the morph there is a line that needs to be set to '1'
valueParm PBMCC_01
name Fireball
initValue 1
hidden 0If it is a linked up Full Body Morph, then set it on there only. If it isn't linked up to a dial on the Body, then do it for whatever body parts you want it applied to.
--Rebekah--
make sure this is set too
initValue 1
hidden 0
enabled 1
forceLimits 1
min -1
max 1
trackingScale 0.02
keys
static 0
k 0 1 <<<<-------------
Locked Out
No matter what I try, all I can get an INJection to do is inject the custom morph into Victoria 4.2; the injected custom morph does not auto-apply once the morph has been loaded.
HOW can I force Poser 6-9 to auto-load a custom morph once that morph is injected into V4.2? The morph applies just fine once the injected dial is spun.
Note: custom morph is full body morph that uses no proprietary morph packs.
I own: Poser 6,8,9
syrINJ
Injection Pose Builder
Injection Magic
Poser File Editor
Poser Tool Box
Morph Manager
PoserWriter Premium
etc.(and a bunch of other stuff)
