Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 19 3:46 am)
"Oh - the manual says that? I have never read the manual - this must be why."The question is, is there some trick I'm missing, or is it simply a useless tool?
"Oh - the manual says that? I have never read the manual - this must be why."----------------------------------------------------------------------------------------
"Oh - the manual says that? I have never read the manual - this must be why."I use the faceroom often as a starting point to make face morphs for any supported figure. Then, once I have the face in a shape I ca use, I apply shape only. Sometimes I do further work either with the morphing tool outside the face room or in Blender.
The fextures generated by the faceroom itself are very low resolution and could be used for background figures but I have never really found a use for faceroom textures.
Using photos (or as you have done here, rendered images), I haven't had any success. I can never get the texture to line up properly, and the texture ends up looking weird because the lighting is not even. So, on the texture part of the faceroom I have pretty much given up.
Poser 11 Pro, Windows 10
I tried it a long time ago and had no luck at all.
I use photos but do in manually in Photoshop but cutting and stretching the photos on layers until they fit the template then work back and forth between Poser and Photoshop until everything fits correctly.
Mike
If you shoot a mime, do you need a silencer?
Quote - That's odd that the texture didn't appear on Roxie. You should think about reporting that with some repeatable steps. I'm fairly certain you should at least see a texture. It may not be good but something should be there.
Just load the front picture above in this thread in the Face Room and her face becomes a black void...
"Oh - the manual says that? I have never read the manual - this must be why."This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
"Oh - the manual says that? I have never read the manual - this must be why."“I could buy better software, but then I'd have to be an artist and what's the point of that?"
