Thu, Feb 13, 5:07 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 13 3:49 pm)
Subject: How does a figure grab cloth?
jbearnolimits ( ) posted Fri, 21 February 2014 at 11:11 PM ยท edited Thu, 13 February 2025 at 4:37 AM
I am learning how to use the cloth room and now know how to make clothes drape on a posed figure but how do I make it so that the person can grab the clothes and lift them as if to remove the clothes? I have poser 6 by the way. Any good step by step tutorials you know of?
basicwiz ( ) posted Fri, 21 February 2014 at 11:14 PM
One trick I use is the drape the item over a cone and run the sim from there. Remove the cone and place the top of the simmed object in the figure's hand!
rokket ( ) posted Sat, 22 February 2014 at 12:38 AM
Constraints?
Or am I reaching?
jbearnolimits ( ) posted Sat, 22 February 2014 at 1:54 AM
Quote - One trick I use is the drape the item over a cone and run the sim from there. Remove the cone and place the top of the simmed object in the figure's hand!
I am wondering how this would work in an animation?
parkdalegardener ( ) posted Sat, 22 February 2014 at 8:29 AM
If you need to move cloth attached to the hand try this:
1 move hand to cloth
2 constrain the cloth vertices to the hand where it touches the cloth
3 run sim. the cloth will stay attached to the hand during the sim but flow as normal everywhere else.
jbearnolimits ( ) posted Sat, 22 February 2014 at 5:59 PM
Quote - If you need to move cloth attached to the hand try this:
I will have to try this. Is there a way to run the simulation before the hand gets close to grab is without the constaint? Then after the constraint finishes it's job can you turn it off again and continue the animation?
parkdalegardener ( ) posted Sun, 23 February 2014 at 5:46 AM
Quote - > Quote - If you need to move cloth attached to the hand try this:
Certainly. The easiest would be to make three seperate animations and string them together in your video editor but Poser would happily do it all in one single animation.
