Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 14 12:36 pm)
Thanks for the reply. I did check the Heirarchy Editor and most of the room componenets were parented to the floor. (I was rotating the wrong floor before, temp on that I added during compositiion. ) THis saved be a bunch of time. (thank you)
The rest of the items in the room were parented to UNIVERSE. I had to manually reassign each one. I wish there was a feature or a script to allow you to select many figures/props in a room and change a parameter that applies to all of them, like paraent. Seems like a script that I have heard of somewhere.
Dlm4001
I purchased a room with funiture and items. The room and all items loads as props. I want to use the room turned 90 degrees from what it loads by default. Is there a way to group all of these props for rotation? I normally go into all 30 or 40 items and assign a new parent like floor. and then rotate it. This just seems like the hard way. Is there a trick to getting all the objects to to rotate as one object or group?
I could load a null object, assign all the lights to it and just rotate the custom light set, but I want the references aligned with the view (z axis).
thanks for any help,
dlm4001
