Sat, Jan 25, 9:37 AM CST
Subject: Weird things with morph files.
jjroland ( ) posted Tue, 04 March 2014 at 4:14 PM · edited Sat, 25 January 2025 at 9:18 AM
Okay so I have a full set of Utility morphs I created for posing.  They are morphs to do things like depress the finger tips, palms, foot pads, etc.
I used 'Create Morph Injections' From Dimension 3ds tool collection.
Now I wanted to set it to where dials only appeared on the Body actor and the actors the morph applied do.
So for instance I have a Depress Index morph.  The dial will be seen on the Body, and the Index 1 for both hands.
However I'm getting very odd results with the Body dial.  It follows no apparent rhyme or reason.
On some of the morphs it causes the head to scale, some the feet, one the head turns.  One scales the length of the shins.
If I select the actual actor the morph applies to and just turn the dial from there I don't have problems.  So one option is to just hide the body dial.
But I was hoping to have all the morphs list on the body actor so that they could all be easily found.
Any clues as to why this happens?
Anyone willing to take a look a the .pz2 for me to see if they see the problem?
I am:  aka Velocity3d
markschum ( ) posted Wed, 05 March 2014 at 12:03 AM
could you  email me one of your inj pose files ?    marks542004@yahoo.com
it sounds like you are getting a master-slave dial setup with the wrong slave.
PhilC ( ) posted Wed, 05 March 2014 at 12:07 AM
I'll be happy to take a look.
pcooke@philc.net
jjroland ( ) posted Wed, 05 March 2014 at 8:41 AM
Yes and yes.  Thank you.  I was crossing my fingers hoping someone  had responded lol.
markschum ( ) posted Wed, 05 March 2014 at 10:24 AM
I have sent you an email.
what I see is - apparent erc code on the master dial , pointing back to itself.
  • the morph uses a new channel name rather than one of the PBM_CC  names. It may be fine but its not how I learned to make them.
PHILC will give you a definite answer. He does this stuff far more often than I do.
jjroland ( ) posted Wed, 05 March 2014 at 10:41 AM
Quote - I have sent you an email.
Thanks so much for looking.  I've had my suspicions too that the lack of the PBM_CC names were the problem.  But I feel like I must be missing something because you'd think that a vendor utility wouldn't have that type of problem.
"what I see is - apparent erc code on the master dial , pointing back to itself."
Would you be willing to explain this a little more?  Is this the :5 problem you referred to in email?  I don't want to come off as completely dense but it's been a looooong time since I made any morphs and I'm not sure what 'erc code' is.
PhilC ( ) posted Wed, 05 March 2014 at 11:49 AM · edited Wed, 05 March 2014 at 11:51 AM
INJ files inject information into channels that already exist in the figure. Your file "Depress Calf Inner INJ.pz2" wants to inject information into a channel named "Depress Calf Inner". If that channel is not already present in the figure then the injection has no where to go.
targetGeom NAME_OF_EXISTING_CHANNEL
name YOUR_NAME_HERE
The first (internal) name must match an existing channel. The second (external) name can be whatever you want it to be. Poser works its ERC code on the internal name, the user only sees the external name.
Also it is probably best to have all the indices and Figure numbers set to one, currently they are set to five. Poser may be able to compensate for that and to be sure one would need to test it, but when I do it I stick with one.
Hope that helps.
jjroland ( ) posted Wed, 05 March 2014 at 12:05 PM
It does.
Is there a list somewhere with the names of existing channels for V4 / M4?
markschum ( ) posted Wed, 05 March 2014 at 4:26 PM · edited Wed, 05 March 2014 at 4:29 PM
PBMCC_xx where xx is 00 to 60  , it should be visible in the cr2.  If you are injecting other vendors morphs as well be aware that they may be using the same channels names.
If you dont have the free utility cr2edit you might want to get a copy. It makes some things easier.
