Fri, Feb 14, 12:01 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 13 7:49 pm)
Subject: Make prop visible when working with it, but invisible in render
digitani ( ) posted Sat, 08 March 2014 at 9:37 AM · edited Fri, 14 February 2025 at 12:00 AM
I have a prop that is only there for interacting with my script, and I want the user to be able to see it when working in the posing room, but I don't want it to show in the render.  Is there any way to do this?
I have tried applying a totally transparent material, and that does hide it in the render, but it is very hard to see it in the posing room.
Check out my website: http://www.digitani.com
willyb53 ( ) posted Sat, 08 March 2014 at 9:42 AM
did you try unchecking visble in camera?
Bill
bagginsbill ( ) posted Sat, 08 March 2014 at 9:48 AM · edited Sat, 08 March 2014 at 9:49 AM
Also uncheck visible in raytracing and casts shadows.
If an object is not visible in camera or raytracing (thus invisible to IDL, reflections, refractions) and cannot cast a shadow, then it has 0 impact on the render. It is only seen in pose room.
Note! Visible in camera is a recent addition to Poser. If you're one of those vendors living in a Poser 5 + Daz world, you're out of luck.
EnglishBob ( ) posted Sat, 08 March 2014 at 11:21 AM
Quote - Also uncheck visible in raytracing and casts shadows.
In earlier versions which lack the 'visible in camera' option, the steps above are sufficient as long as you always render using raytracing. I imagine most people do, but I have no data to support that - so you may not want to risk it for a commercial product.
Cage ( ) posted Sat, 08 March 2014 at 12:23 PM
I use one of the wireframe object display style modes, in such cases.  Depending on context, that may or may not help make the object more evident in the workspace.  :unsure:
PhilC ( ) posted Sat, 08 March 2014 at 3:37 PM · edited Sat, 08 March 2014 at 3:37 PM
I believe the one you really want can only be edited within the Poser file itself. Open in a text editor and search for "visibleInRender". Set its value to zero.
Probably a good idea to set the other visibilities/shadows to zero also as stated above.
digitani ( ) posted Mon, 10 March 2014 at 7:38 PM · edited Mon, 10 March 2014 at 7:38 PM
Thank you, everbody!  You are all awesome, but PhilC is the most awesome this time, because that totally worked.  Thanks, Phil!
I set visibleInRender to 0 for all occurences of it in my .cr2 file and now I see it in my preview, but not in the render.  BTW, I did have to set casts shadows to false as well.
Also, I do have an older version of Poser (Pro 2012), so the 'visible in camera' mentioned above was not available to me.
Thanks again,
-digitani
EnglishBob ( ) posted Tue, 11 March 2014 at 5:20 AM
Phil is always the most awesome. Even his facial hair is awesome. :D>
visibleInRender goes back at least to Poser 4 so should be available to anybody.
For Pythonheads: actor.SetVisibleInRender( 0 ) will achieve this. I leave it as an exercise for the reader to work out how to turn it back on again. ;)
estherau ( ) posted Wed, 12 March 2014 at 6:39 AM
what's wrong with just going into the parameters tab in poser and clicking on properties and making the prop invisible?  did you try that?  I know it is basic but maybe he doesn't know this method?
MY ONLINE COMIC IS NOW LIVE
bagginsbill ( ) posted Wed, 12 March 2014 at 7:41 AM · edited Wed, 12 March 2014 at 7:43 AM
Quote - what's wrong with just going into the parameters tab in poser and clicking on properties and making the prop invisible?  did you try that?  I know it is basic but maybe he doesn't know this method?
What's wrong is it would not be visible if you make it invisible. The stated requirement is that it be visible in the posing room.
Quote -  I want the user to be able to see it when working in the posing room
The original question was basically asking how to make it invisible in the render only, because if you make it generally invisible, then it's invisible in the posing room, too, and that is not desirable.
estherau ( ) posted Wed, 12 March 2014 at 7:46 AM
well wouldn't he then just make it invisible when he's finished posing and is ready to render?
bagginsbill ( ) posted Wed, 12 March 2014 at 7:55 AM
The OP is asking how to avoid what you're suggesting the user be forced to do.
It's like you go to the doctor and complain that it hurts to lift your arm, and the doctor says don't lift it, then.
estherau ( ) posted Wed, 12 March 2014 at 8:01 AM
I just re read his original post and I have to say it is a little ambigous.  He may be meaning exactly what you say because he doesn't know how easy it is to turn objects on and off.
But anyway he now has two methods he can use depending what he wants to do.  And he could well be a beginner.
AmbientShade ( ) posted Wed, 12 March 2014 at 9:34 AM
This would actually be useful for a lot of things. Thanks for that.
~Shane
Miss Nancy ( ) posted Wed, 12 March 2014 at 11:54 AM
just to mention, 'visible in camera' chekbox in PP2012 property gui; can also be edited in cr2:
locked 0
backfaceCull 0
visibleInReflections 1
visibleInRender 1
visibleInCamera 1
visibleInIDL 1
digitani ( ) posted Fri, 14 March 2014 at 3:13 PM
Hey, estherau, thanks so much for your input, but Bagginsbill was right.  I'm developing a tool that I want to distribute, and I want it to be as easy to use as possible, so I don't want to tell the users that they have to make the prop-based controls invisible manually before rendering.  I still appreciate your help, though. :-)
EnglishBob, I am a pythonhead, so thanks for that little tidbit as well.
-digitani
estherau ( ) posted Fri, 14 March 2014 at 6:46 PM
oh okay.  hope it works okay.
grichter ( ) posted Fri, 14 March 2014 at 9:00 PM
The phil C method is used on a lot of dresses that have handles that show up in the pose room but not in the render.
Gary
