DAZ|Studio F.A.Q (Last Updated: 2025 Jan 20 7:19 pm)
Yes merge with existing runtime, they are inj poses.
http://www.aldaraproject.com/aldara/
http://www.dreamslayervisions.com
Wont work if you installed it for studio.
Up to genesis carrara used the Poser runtime configuretion, not the Studio content configuration. Carrara can't read studio files previous to genesis; file formats previos to DUF.
Now it used to be mil 4 figures had to be installed in the same folder as your Poser exe was. Installing it the studio "my library" folder may have solved this, but if you install in studio format carrara wont be able to read the studio mat files for skinning the character.
{note: the easy quick fix was just to create a new folder then name it Poser.exe}
This is more of a carrara question then a studio one. But hey, you might get lucky and have it work with no issues. None the less if you intend to use DAZ and other content in carrara it doesn't work the same as it does in Studio.
Quote - Thanks everybody for the help,
I am trying to get a handle on runtime and the file system. Until I can ask more pertinent questions, I won't take up your time. I suppose you have all put you time in trying to get a handle on this problem - it is time I did the same.
Thanks again,
Starboardtack
Oh ya, lots of time lol
I have bought the morphs for M4 from DAZ but it will not install on the download. So I have downloaded them to my HD. What do I do next to install into the right folders ? I cannot find a simple directions on DAZ and I am afraid of putting them in the wrong place and causing other problems.
Do I just drop the files into matching folders on DAZ runtime ?
Thanks for your time and patience.
Mac Os 10.7.3
Starboaard
