Sun, Jan 5, 12:46 AM CST
Subject: Anyone know how to create a netting like shader in Poser?
EClark1894 ( ) posted Sun, 06 April 2014 at 3:50 PM · edited Thu, 01 August 2024 at 9:45 PM
Can it be done? I'm thinking that maybe I could create something like a tile shader with every other tile black. Then making a transmap?
EClark1894 ( ) posted Sun, 06 April 2014 at 3:51 PM
Would really be nice for fishnet stockings too.
Latexluv ( ) posted Sun, 06 April 2014 at 4:57 PM
I have a shader in my Bagginsbill Cloth folder called Fishnet. I know he made and posted this one a long time ago. Here's the screenshot.
Weapons of choice:
bagginsbill ( ) posted Sun, 06 April 2014 at 5:04 PM
Good catch, LL!
I've been searching my posts for the last 45 minutes for that. I found the original thread but you beat me to it. I was having trouble because I didn't use the word fishnet in my post.
http://www.renderosity.com/mod/forumpro/showthread.php?message_id=3620132&ebot_calc_page#message_3620132
Latexluv ( ) posted Sun, 06 April 2014 at 5:34 PM
I've been trying to refind any shader you publically published because of a recent computer crash. Luckily I had some of your older shaders (pre PP2012), in my Poser Pro 2010 program on my external drive. I'm sure I'm still missing a bunch of your shaders! But I remembered using the fishnet shader on a shirt for M3 a long time ago.
Weapons of choice:
Winterclaw ( ) posted Sun, 06 April 2014 at 6:39 PM · edited Sun, 06 April 2014 at 6:43 PM
U and V are supposed to be swapped, right?
Also, shouldn't the tile be plugged into the glossy node somewhere?
WARK!
Thus Spoketh Winterclaw: a blog about a Winterclaw who speaks from time to time.
(using Poser Pro 2014 SR3, on 64 bit Win 7, poser units are inches.)
EClark1894 ( ) posted Sun, 06 April 2014 at 6:40 PM
Thanks, guys! I'll give that a try pronto!
bagginsbill ( ) posted Sun, 06 April 2014 at 6:49 PM
The glossy node is something LL did. My shader originally used white diffuse, not any specular. Rope is not shiny. I'm not sure what she was using that for, but a cotton string net is diffuse only.
The U and V are in the original only to rotate the tiles 45 degrees. You don't need them if you don't care about that.
Winterclaw ( ) posted Sun, 06 April 2014 at 7:09 PM
Ah, ok.
I'm playing with it now on DAZ's bodysuit... the one that comes in one of the V4 packages.  Seams in the UV mesh can be a problem as is trim, so I wouldn't use it on anything but it does nicely.
WARK!
EClark1894 ( ) posted Sun, 06 April 2014 at 7:46 PM
Well, Yes and no.
toastie ( ) posted Sun, 06 April 2014 at 8:01 PM
Maybe you just need to tighten up the scale a lot?
Latexluv ( ) posted Sun, 06 April 2014 at 8:02 PM
I was trying for netting made of plastic strands. Some cheep stuff I saw on a cyber punk model once. Looked decent at the time that I rendered with it.
Weapons of choice:
EClark1894 ( ) posted Sun, 06 April 2014 at 8:20 PM · edited Sun, 06 April 2014 at 8:21 PM
Better. No large strands.
EClark1894 ( ) posted Sun, 06 April 2014 at 9:42 PM · edited Sun, 06 April 2014 at 9:42 PM
I can kind of live with this texture... for the moment. I do need to go back into Blender and work on both the tutu and the leg warmers.
toastie ( ) posted Mon, 07 April 2014 at 9:34 AM
Needs more layers, 3 isn't much for a tutu. Then the transparency will look better. 😄
EClark1894 ( ) posted Mon, 07 April 2014 at 3:51 PM
Quote - Needs more layers, 3 isn't much for a tutu. Then the transparency will look better. 😄
How many layers we talking?
toastie ( ) posted Mon, 07 April 2014 at 5:48 PM
Quote - > Quote - Needs more layers, 3 isn't much for a tutu. Then the transparency will look better. 😄
Usually about 8-10, but you could get away with a few less for a class practice tutu though. I think that like a real tutu it will probably look better the more layers you add.
