Thanks basic Wiz! Just what I was looking for. Apparently it's one of a set of four in the download and done by Chris Cox.
http://www.sharecg.com/v/39163/browse/11/Poser/Stud-Earrings-for-Poser
Cool Render BBill!
Hmm Chris Cox.
The name rang a bell and I checked my files. He did a nice gold necklace freebie on Dragonspace if you haven't seen it:
http://dragonspace.com/wordpress/?p=305
And DaremoK3/SpookieLil one made a freebie pendant to go along with it. I can't figure out how to get a picture to load here, but I'll pass along the link:
http://www.sharecg.com/v/39054/View/11/Poser/Faerie-Star-Pendant-For-Victoria-4
By the way. if any rendo moderators are reading, when I go to insert a link to make a line an active link (as above) the pop-up comes up blank and takes what seems ages to fill. It's not just this time. Using Firefox.
Quote - And omg I want that shader!
It's simple.
Turn off the built-ins: Diffuse_Value = 0 and Specular_Value = 0.
Attach Fresnel_Blend to white Alternate_Diffuse. Set IOR = 2.5
Attach Reflect to white Fresnel_Blend Outer_Color.
Attach Refract to white Fresnel_Blend Inner_Color. Set IOR=2.5
Quote - > Quote - And omg I want that shader!
It's simple.
Nice, I'd already been using essentially that setup; I just hadn't done a render that close before.
Pretty much a straighforward question. Just looking for a small simple diamond stud earring prop for the Daz Characters, preferably V4 at the moment, but a smart prop for any will likley do.
I do a search and then am combing through a lot of items that are not relevant. I suspect that what I want is so simple it is part of a larger package and may not be labeled anywhere, or it may even be a freebie that I am not aware of.
Thank you.
