Sun, Nov 24, 12:58 PM CST
Subject: Genesis - newbie ...
A_Sunbeam ( ) posted Tue, 03 June 2014 at 12:12 PM · edited Sun, 24 November 2024 at 12:49 PM
I have installed the Dyson stuff and the G2 female. I then bought an outfit for her. Everything installed as instructed.
But why do clothes take so long to be loaded? I opened the file, chose the suit - which appeared on the screen, and was about to select "conform to ..." when a "projection" panel opened. At the time of typing this is has been 'projecting' for 21 minutes and still not finished.
Question - is this normal? Or have I done something wrong?
Shaun
(PoserPro2014 on MacBook)
JimTS ( ) posted Tue, 03 June 2014 at 4:14 PM
Yes this is "normal"
Your error was expecting much of anything else.
That DSON thing is sketchie.
A word is not the same with one writer as with another. One tears it from his guts. The other pulls it out of his overcoat pocket
Charles Péguy
 Heat and animosity, contest and conflict, may sharpen the wits, although they rarely do;they never strengthen the understanding, clear the perspicacity, guide the judgment, or improve the heart
Walter Savage Landor
So is that TTFN or TANSTAAFL?
Vaskania ( ) posted Tue, 03 June 2014 at 4:59 PM
Go into the importer preferences (script > daz/dson/whatever) and turn off the progress bar. It will still take a minute (or less/more depending on your system), but turning that bar off can usually help things out.
-----sig-----
Daz, Blender, Affinity, Substance, Unity, Python, C#
moriador ( ) posted Wed, 04 June 2014 at 12:02 AM
21 minutes cannot be normal.
For me, an outfit usually takes about 4 or 5 seconds for each figure in the outfit. Genesis itself may take a minute or two because I have a ton of morphs installed.
Depending on the speed of your machine, it may take more or less time. But I'd be shocked to find that 21 minutes was normal, even for lower end machines.
A_Sunbeam ( ) posted Wed, 04 June 2014 at 3:22 AM
Thank you for the replies.
Second problem ... Having got the outfit to load and conform I find the figure's bust poking through. Normally the outfit can be adjusted to fit using the dials for the chest or body - but with the Genesis outfit there are no such dials - and again - have I done something wrong, or is this normal? In which case how do I adjust clothing to fit? Sorry if this is all elementary stuff, but I can't find a "how to do it" anywhere.
Male_M3dia ( ) posted Wed, 04 June 2014 at 9:15 AM
Quote - Thank you for the replies.
You should find an option "Transfer active morphs" in the DSON menu. That menu is under the 'Scripts' menu in Poser. I would use it after you get the model posed for the best results.
hborre ( ) posted Wed, 04 June 2014 at 9:25 AM
Online Now!
If you notice the OP's image, Genesis is still subdivided which explains why the outfit is taking longer to conform.  After importing Genesis/Genesis2, you must go back to the DSON script and select zero subdivision, otherwise anything you attempt to do will impact on Poser's reaction time and speed.
A_Sunbeam ( ) posted Wed, 04 June 2014 at 10:15 AM
Thank you.
