DAZ|Studio F.A.Q (Last Updated: 2025 Jan 31 8:48 pm)
Tutorial?
Load G2M, go to the genesis folder, select/load the clothes.
Select the clothes in the scene tab, general tab{right side}, fit to, genesis, select a clothing type. Done.
I'd do screen caps but I'm not sure which interface you may be using so they could be confusing.
Unless you are having issues with an artical of clotheing, then we'd need more info
And thanks, I don't use G2F/M much becaise that aren't real carrara compatable, but till I checked for this thread I didn't know there was a full length rode setting for autofit for G2M
I'm not at my computer right now, but as I recall, down on the lower right hand side of the screen when you start up DS there is a small drop down called "Select Lesson", click on it and you should see your newly installed tutorial(s) in the list (if I'm correct in guessing that you mean the recent free tutotials that DAZ had).
Hope this helps!
__________________________________________________________
My Rendo Gallery ........ My DAZ3D Gallery ........... My DA Gallery ......
Where the heck is it? It was downloaded and installed but no trace was left as to where to locate it or how to use the .dsa file.
Please?
