Tue, Nov 26, 3:31 PM CST
Renderosity Forums / Blender
Welcome to the Blender Forum
Blender F.A.Q (Last Updated: 2024 Nov 24 8:44 pm)
Welcome to the Blender Forum!
   Your place to learn about Blender, ask questions,
   exchange ideas, and interact with the other Blender users!
   Gallery | Freestuff | Tutorials
Visit the Renderosity MarketPlace. Your source for digital art content!
Subject: Newbie trying to put up a background image
wealthychef ( ) posted Mon, 30 June 2014 at 9:53 PM · edited Tue, 26 November 2024 at 1:51 PM
I have a scene with some objects in it and wish to add a background of a tiled image to add interest, replacing the sky color with a tiled image.  Is this possible in blender?  I'm rendering using 'CYCLES'.   I tried to go to World -> Surface -> Color:  Image Texture and it does nothing but turn the background off-white.   I tried putting a giant cube around my scene, then adding an Image Texture node but no luck.  Help anyone?  :-)  I'm attaching a screen shot FWIW.  Thanks!
Lobo3433 ( ) posted Mon, 30 June 2014 at 10:09 PM · edited Mon, 30 June 2014 at 10:10 PM
Forum Moderator
While in the node editor click on add and their is a background node you can add but it might not show up in 2.70 I know in 2.71 I had to click add and scroll down to search "background" and enter and it adds the background node. I still a novice with cycles myself but that was the quickest answer I could find at the moment if that does not help I am confident another of our forum members will chime in if they have a better answer.
Good Luck
Lobo3433
Renderosity Store
My Free Stuff
Facebook
Twitter
wealthychef ( ) posted Tue, 01 July 2014 at 11:27 AM
Thanks.  I already have a Background node with an Image Texture feeding into it.  I'm attaching the World view from the Node Editor to show what I mean.  It ain't working!  Grrr
wealthychef ( ) posted Tue, 01 July 2014 at 1:33 PM · edited Tue, 01 July 2014 at 1:34 PM
Found a solution:  use the "Environment Texture" node instead of "Image Texture" per [ http://wiki.blender.org/index.php/Doc:2.6/Manual/Render/Cycles/World ](http://wiki.blender.org/index.php/Doc:2.6/Manual/Render/Cycles/World)
However, this does NOT tile the image.  Anyone know how I can tile the image acroos the background instead of having a huge image?
heddheld ( ) posted Tue, 01 July 2014 at 3:51 PM
enviroment tex is "usualy" an hdr (dosnt have to be ) so wouldn't really be tilable
could try adding a mapping node then scale it from there , never tried that so not 100% it would work
or could load a plane and add your tile to that just have to get scales/angles right for cam view
pauljs75 ( ) posted Wed, 02 July 2014 at 6:29 AM
Quote - Anyone know how I can tile the image acroos the background instead of having a huge image?
Input>Texture Coordinate (Generated, Window, or Camera) plugged into Vector>Mapping, which is then plugged into the vector socket on your image texture. X and Y scaling settings should do the job. Other adjustments of interest are Z-rotation and X and Y location.
Barbequed Pixels?
wealthychef ( ) posted Sat, 05 July 2014 at 12:35 PM
Quote - Input>Texture Coordinate (Generated, Window, or Camera) plugged into Vector>Mapping, which is then plugged into the vector socket on your image texture. X and Y scaling settings should do the job. Other adjustments of interest are Z-rotation and X and Y location.
Sounds excellent, I'll try that too.  What is working very well in my case now was to create a hexahedron (anisotropically scaled cube) around my scene and texture an image onto it.  Gives exactly the effect I want for my project.
kyraia ( ) posted Tue, 22 July 2014 at 6:13 AM
Hello wealthychef,
try this (in Blender 2.71): World -> Surface: Background, Color: Environment Texture
I took a landscape from cgtextures.com in the example (which is unfortunately not tiled so what you see depends on the view angle).
Note: the background is only visible in rendered preview!
Kyraia
