Wed, Dec 4, 3:01 PM CST
DAZ|Studio F.A.Q (Last Updated: 2024 Dec 03 7:51 pm)
Subject: reality not loading all objects
wisdomseeker423 ( ) posted Tue, 08 July 2014 at 12:39 PM · edited Thu, 25 July 2024 at 8:48 AM
So I began a scene in daz studio and everything for the most part went well. I attempted to load it into reality 2.5 in order to port to luxrender and found that one of my terrain objects isn't getting any texture at all. It just shows up as a greyform. It is a copy of one other texture object I have going and thus bears the same name. I am wondering if this is the problem, as only one of the terrains even shows up in the reality material list. There is no problem rendering in 3delight but in lux it is simply a greyform. Anyone else having this problem?
SickenlySweete ( ) posted Tue, 08 July 2014 at 1:06 PM
Pret-a-3D ( ) posted Tue, 08 July 2014 at 1:21 PM
If you have imported the object as an OBJ then Studio does not use a unique name for it. Check you scene. Do you have two objects with the exact same name? If so that is the cause of the issue. Rename the object to have unique names and possibly apply the materials manually to one of them and the issue will be resolved.
Hope this helps.
Paolo
https://www.preta3d.com
FB: https://www.facebook.com/RealityPlugIn
Tw: @preta3d
G+: https://plus.google.com/106625816153304163119
The Reality Gallery: https://reality-plug-in.deviantart.com
wisdomseeker423 ( ) posted Tue, 08 July 2014 at 1:58 PM
Actually it would. How do I rename the object? I right click and there is no option for it. That would probably be the cause of the issue.
Pret-a-3D ( ) posted Tue, 08 July 2014 at 2:24 PM
To rename an object you click to select and then click again. It'snot a double click, it's two clicks.
Cheers.
Paolo
Tw: @preta3d
wisdomseeker423 ( ) posted Tue, 08 July 2014 at 2:32 PM
Well...while it didn't let me rename it, it did begin to show up in reality under the same name with a (2) behind it. Now the render is working so thank you very very much. :)
klown ( ) posted Wed, 09 July 2014 at 1:52 PM
Quote - Well...while it didn't let me rename it, it did begin to show up in reality under the same name with a (2) behind it. Now the render is working so thank you very very much. :)
Click twice in the content pane in Studio.
I don't think you can rename from the Reality list of surfaces.
Pret-a-3D ( ) posted Wed, 09 July 2014 at 3:55 PM
No, you cannot rename objects in Reality. You need to click twice in the Scene tab of DAZ Studio.
Cheers.
Paolo
Tw: @preta3d
