DAZ|Studio F.A.Q (Last Updated: 2024 Dec 09 1:48 pm)
Re apply the textures by hand in reality
http://www.aldaraproject.com/aldara/
http://www.dreamslayervisions.com
If you have imported the object as an OBJ then Studio does not use a unique name for it. Check you scene. Do you have two objects with the exact same name? If so that is the cause of the issue. Rename the object to have unique names and possibly apply the materials manually to one of them and the issue will be resolved.
Hope this helps.
Paolo
https://www.preta3d.com
FB: https://www.facebook.com/RealityPlugIn
Tw: @preta3d
G+:
https://plus.google.com/106625816153304163119
The
Reality Gallery: https://reality-plug-in.deviantart.com
To rename an object you click to select and then click again. It'snot a double click, it's two clicks.
Cheers.
Paolo
Tw: @preta3d
G+:
The
No, you cannot rename objects in Reality. You need to click twice in the Scene tab of DAZ Studio.
Cheers.
Paolo
Tw: @preta3d
G+:
The
So I began a scene in daz studio and everything for the most part went well. I attempted to load it into reality 2.5 in order to port to luxrender and found that one of my terrain objects isn't getting any texture at all. It just shows up as a greyform. It is a copy of one other texture object I have going and thus bears the same name. I am wondering if this is the problem, as only one of the terrains even shows up in the reality material list. There is no problem rendering in 3delight but in lux it is simply a greyform. Anyone else having this problem?
