Haven't seen this mentioned so far, so just a note. When I installed it as per Snarly's instructions from May and then restarted Poser, I only got the top line of the interface, i.e. the figure/actor/material/sync line. Had no idea what to do.
Out of the blue, I decided to see if the font resize instructions worked, and when I resized the font, all of a sudden the rest of the interface was there.
All that to say: if you don't see the whole interface, right click and resize the font.
Okay, I'm about to play now ... thanks so much, Snarly!
______________
Quote - Haven't seen this mentioned so far, so just a note. When I installed it as per Snarly's instructions from May and then restarted Poser, I only got the top line of the interface, i.e. the figure/actor/material/sync line. Had no idea what to do.
Thanks for the tip. I find it is random in that I have been using EZMat for about a week now and it has worked fine, then yesterday it suddenly displayed only the top line of the interface. I was stuck for time so did not look any deeper for fix so, having read your post, I launched Poser and EZMat is fine. Reloaded the same scene and again it is fine.
Not sure why this is but at least next time I will have a fix for it, so many thanks.
I use Poser 13 on Windows 11 - For Scene set up I use a Geekcom A5 - Ryzen 9 5900HX, with 64 gig ram and 3 TB storage, mini PC with final rendering done on normal sized desktop using an AMD Ryzen Threadipper 1950X CPU, Corsair Hydro H100i CPU cooler, 3XS EVGA GTX 1080i SC with 11g Ram, 4 X 16gig Corsair DDR4 Ram and a Corsair RM 100 PSU . The desktop is in a remote location with rendering done via Queue Manager which gives me a clearer desktop and quieter computer room.
Snow machine version v2.1.0 for Macs, works with P9/PP2012
http://snarlygribbly.org/3d/forum/viewtopic.php?f=7&t=15&sid=82a2b5ee03812bb99a72602eaa83561c
And I think the EZMat (back to the topic, LOL), has a version of snow machine too:
http://snarlygribbly.org/3d/forum/viewtopic.php?f=34&t=172&sid=82a2b5ee03812bb99a72602eaa83561c
visit www.aRtBeeWeb.nl (works) or Missing Manuals (tutorials & reviews) - both need an update though
So much awesome...
I've had a question about snow machine, maybe I asked before but I don't remember the answer... Does it need actual geometry to work properly, or will it also produce snow accurately on displaced details?
I've long tried to figure how to model power and phone lines in urban environments. One of the things I tried was just drawing slight curves on planes and using those instead of actual geometry. If the lines were displaced slightly, would snow "collect" on them?
proof: same pawn, turned into mossy rock (EZMenhir plugin to EZMat) with either low displacement or extreme displacement (the XMas tree needles), with and without snow. SnowMachine takes displacements, even extremes.
yeah, making progress.
I can't believe it's been 9 years since reading a thread and saying "I want to mess around with this technique someday"... But I guess it really has been.
So I'm curious, does/will EZMat have any options for rust or grime as seen in this ancient, but still inspiring, thread?:
http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2177495&page=1
Nine years, and still on my to-do list... :sad:
hi moogal,
you can grab EZMat from Snarly's place already, and start playing...
we're just working on documentation (and more improvements...)
I use EZSkin and I've been following this thread from the beginning... Just tied up using Poser for another project and waiting for a chance to really enjoy diving in...
But it (AO/cavity/dirt shader) was once a hot topic, (and I guess still is with me) BB seemed amused that it came up again in 2011 when that thread was merely 6 years old. :blink:
I am strangely intimidated by really cool tools. I'm have a fear that I might wade in too deep and never be seen again.
(mutters "It's full of stars...")
very interesting and exciting!
I aim to update it about once a month. Oh, and it's free!
Quote - I change the resolution screen an the problem are the same
I missing something?
Change the font size used by EZMat. This will cause it to resize the controls too, so that everything can fit.
You can rezise the font by right clicking on the UI background and selecting the change font size option from the popup menu, or on the EZMat preferences tab.
Free stuff @ https://poser.cobrablade.net/
This has worked for other display issues, so I'll suggest this:
Go to the main (first) materials tab.
With your cursor in the upper area of the interface, right-click and select Set font-size. Make the font size smaller.
At bottom right of the EZSkin screen there should be two more lines:
Apply gamma correction (with a checkbox)
Do it-convert all materials! (that's a button)
______________
Quote - > Quote - I change the resolution screen an the problem are the same
I hate to ask...but the plug in folder? where does that go?
https://www.darkelegance.co.uk/
Just to let you know that three new plugins have been posted to my site (3d.snarlygribbly.org)
EZGhost - turns an object into something ghostly
EZFix - some of the functions from SceneFixer made into an EZMat plugin for convenience
BBFire - Add flames to an object using a Bagginsbill shader published on another site. (NB: The idea is to duplicate the object in Poser and apply the plugin to the duplicate so that the original object 'shows through' the flames. Of course, that method is optional)
Thank you so much for EZMat and the plugins. I use EZMat all the time now and I have just downloaded the new plugins so I can have a play this weekend.
Quote - Just to let you know that three new plugins have been posted to my site (3d.snarlygribbly.org)
Can't get the plugins. I follow the link in your sig and click on EZMat thread and site wants a login in order to view. I do not recall this happening before.
Weapons of choice:
Quote - Can't get the plugins. I follow the link in your sig and click on EZMat thread and site wants a login in order to view. I do not recall this happening before.
Here: http://www.snarlygribbly.org/3d/forum/viewtopic.php?f=34&t=172
Oh wow! that looks wonderful! I wonder how it would look in Reality.
OS: Windows 11 64-bit
Poser: Poser 11.3 ...... Units: inches or meters depends on mood
Bryce: Bryce Pro 7.1.074
Image Editing: Corel Paintshop Pro
Renderer: Superfly, Firefly
9/11/2001: Never forget...
Smiles are contagious... Pass it on!
Today is the tomorrow you worried about yesterday
From Snarly's post midway down page 19 (Posted Wed, Jun 4, 2014 11:02 pm)...
Quote - ...Don't be afraid to ask questions, even if they seem dumb - EZMat is NOT a straightforward plugin...
I just discovered and downloaded the free version (plus all the extras) from Snarly's Space and unzipped it all to a temporary runtime H:Poser!TEMPRuntime , and I have a bunch of stupid questions: :)
I assume that 'init.pyc' should go in Runtime/Python/addons/EZMat ? (I read somewhere in this thread that it can be ANY runtime, and doesn't have to be the main one where the poser.exe resides)
I assume the 'Plugins' folder should be under 'EZMat' and that all the 'ez_BBAsphalt.py', etc files should go in there?
What about the CFG files ('EZBrick presets.cfg', etc)? In 'EZMa't or 'EZMat/Plugins'?
I've put the tutorial and developer stuff into separate 'Tutorial and 'Developer folders to keep them separate - I guess that's okay?
Now how do I go about firing it up? Do I go 'File > Run Python Script' and select init.pyc, or what ?
(I've searched through many, but not all, pages of this thread to find the answers without any luck yet...)
TIA
The 3Dcheapskate* occasionally posts sensible stuff. Usually by accident.
And it usually uses Poser 11, with units set to inches. Except when it's using Poser 6 or PP2014, or when its units are set to PNU.
*also available in ShareCG, DAZ, and HiveWire3D flavours (the DeviantArt and CGBytes flavour have been discontinued).
Quote - 1) I assume that 'init.pyc' should go in Runtime/Python/addons/EZMat ? (I read somewhere in this thread that it can be ANY runtime, and doesn't have to be the main one where the poser.exe resides)
Yes, that is correct.
Quote - 2) I assume the 'Plugins' folder should be under 'EZMat' and that all the 'ez_BBAsphalt.py', etc files should go in there?
The plugins folder can be anywhere on your computer system. You can have multiple folders too. On the EZMat Materials tab there is an option to select the folder containing the plugins you want to work with. on the Preferences tab you can preselect several folders for convenient access.
Quote - 3) What about the CFG files ('EZBrick presets.cfg', etc)? In 'EZMa't or 'EZMat/Plugins'?
Save them anywhere. Select a plugin, then choose the 'import presets' button to select the appropriate file. After you have imported the presets you can delete the cfg files.
Quote - 4) I've put the tutorial and developer stuff into separate 'Tutorial and 'Developer folders to keep them separate - I guess that's okay?
Yes
Quote - 5) Now how do I go about firing it up? Do I go 'File > Run Python Script' and select init.pyc, or what ?
Windows>Addons>EZMat
Quote - (I've searched through many, but not all, pages of this thread to find the answers without any luck yet...)
aRTBee is organising the production of some documentation for EZMat. From the early drafts I've seen I think it is going to be excellent.
Just to let everyone know what's happening behind the scenes with EZMat:
Work on it has continued and I now have a development version which allows one plugin to be overlaid atop another (or any other shader from any source).
This will enable plugins to be made for soap suds, dirt, tattoos, scars, peeling paint, makeup etc.
I'm hoping to release the development version to a few select testers and aRTBee's team at the weekend. Once I know that it is robust and working I'll release it to everyone, for free :-)
Many thanks for those answers! (I just installed your EZSkin2 freebie too and guessed that the cfg files would probably work in the same way - i.e. import them once).
Time to start playing... :)
Quote - Just to let everyone know what's happening behind the scenes with EZMat:
Amazing! Thank you for your generosity :)
― Marcus Aurelius,
Just completed a big test render (took all day) with EZSkin2 and IDL - fantastic, with more work needed on my part to set things just right.
Now started playing with EZMat to try and get some jewellery looking good. Got the plugins loaded and the presets imported, but I ran into two problems:
EZMat doesn't seem to know about the selected figure (see attached image) even after pressing 'Sync' - I tried closing EZMat, going the material room and opening it again. Same problem.
Even with drag-docking disabled it always docks if I drag it in the material room. (Edit: I tried again several times - same problem. Tried again and it works properly, doesn't dock. Go figure!)
Any ideas anybody?
(Poser 9.0.3.23027, Windows 7, EZMat v1.1 build 0102)
Hmmm. Don't know what happened there. Just restarted Poser and it works fine - Andy's now made of asphalt and he looks marvellous!
You can right click on the UI background to get a menu that lets you control the docking behaviour ...
Thanks so much! The chair with the leather shader looked really good, but with V4 sitting on in and final render settings, it took nearly six hours to render.
Weapons of choice:
