Be sure that;
If it is still hollow when rendering, it is usually(?) the settings used in the program that had exported the mesh (sculptris , zbrush, etc)
I'm not familiar with sculptris.
AS
Contact Me | Gallery |
Freestuff | IMDB
Credits | Personal
Site
"I want to be what I was
when I wanted to be what I am now"
I just imported an .obj dodecahedron and cut it's top off with a Bryce cube. The thing to remember is the object you are altering has to be Positive in the attributes and the Cutter object(my cube) must be negative
Once
in a while I look around,
I see
a sound
and
try to write it down
Sometimes
they come out very soft
Tinkling light sound
The Sun comes up again
You gotta love this place!
This used to be the go to place for all things Bryce. Not too much nowadays, but I'll ask this here anyways.
I imported an .obj from sculptris and was going to boolean a portion of it to slice a flat spot on it. The imported object is being rendered as a hollow shell and not a solid similar to terrains that have not been made solid and you try to do a boolean operation on it.
Is there a trick anyone knows to correct this? I wanted to transfer the material of the negative object to form a flat spot on the larger object but all I get is a view of the interior imported object.
