Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 20 7:34 am)
Windows 7
**Processor(s)
System Memory
BIOS Information
Motherboard Information
Video Adapter
Hard Drive(s)
Optical Drives / Other Storage
OperatingSystem: MS Windows 7 Business Edition
DirectXVersion: DirectX 11
IRQ Configuration
Miscellaneous
Final Checks
Installed Devices Drivers
Burn-In/Benchmarks
Although from different manufacturers your spec is not a million miles away from mine and Poser 2014 is installed and stable on my system. I now use the Game Dev version but that is really Poser 2014 with added features and I ran Poser 2014 for years before that, again no issue.
I use Poser 13 on Windows 11 - For Scene set up I use a Geekcom A5 - Ryzen 9 5900HX, with 64 gig ram and 3 TB storage, mini PC with final rendering done on normal sized desktop using an AMD Ryzen Threadipper 1950X CPU, Corsair Hydro H100i CPU cooler, 3XS EVGA GTX 1080i SC with 11g Ram, 4 X 16gig Corsair DDR4 Ram and a Corsair RM 100 PSU . The desktop is in a remote location with rendering done via Queue Manager which gives me a clearer desktop and quieter computer room.
I keep getting executable file has stopped working I have installed it and un installed it several times. going nuts.
Make sure it has adequate permissions under UAC in order to do everything it needs to do. When it "stops working", what is it doing? Does this happen right after you click the executable? If so, it's probably a permissions/security issue, since you've reinstalled it several times. Check any security software you have installed and make sure it allows Poser access to what it needs. For instance, even though Poser doesn't connect to the net, unless you tell it to, it may still need to access certain ports in order to carry out logical operations.
Also, make sure it's patched up before you start it. There's a problem with Internet Explorer 11 that was mentioned earlier. The only way Poser 2012 Pro runs on my machine is if I don't have IE11 installed, despite patches. You might want to revert to IE10, just to see if that fixes the problem.
i'm going to attempt installing P7 and PP12 on W8.1. >.< scared! dual celeron netbook.
♥ My Gallery Albums ♥ My YT ♥ Party in the CarrarArtists Forum ♪♪♪ 10 years of Carrara forum ♥ My FreeStuff
