Mon, Nov 11, 5:24 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2024 Nov 05 6:06 am)
Carrara Free Stuff here.
Subject: Indoor Lighting: store-type environment - any hints?
graylensman ( ) posted Fri, 17 April 2015 at 9:05 AM · edited Mon, 11 November 2024 at 5:22 AM
Greetings, all! I have a model to render in a grocery store environment. For the life of me, I can't quite get lighting like I want! I've looked at a dozen different tutorials, and they generally divide into two types of lighting - the traditional three-point technique and the great outdoors. I have yet to find anything that addresses what I'm looking for. I've basically defaulted to a mix of Global Illumination, ambient light, and maybe a spot or two. This gives acceptable results, but still isn't quite right.
Can anyone point me in the direction I'm looking for? Thanks as always!
MarkBremmer ( ) posted Fri, 17 April 2015 at 10:06 AM
You'll need a light array to get things to look ok. I've used a collection of tube lights in the past with pretty good success. I'll see if I can put together a sample in a few minutes when I wrap what I'm working on.
graylensman ( ) posted Fri, 17 April 2015 at 10:18 AM
Thank you so much!
MarkBremmer ( ) posted Fri, 17 April 2015 at 10:49 AM
I set the Tube lights to about 20% strength with soft shadows enabled (adjust softness to your liking)
The top Distant lights are set to 90% strength, no shadow.
The bottom Distant lights are to fake bounce light. They are set to 15%, no shadows.
Doing this prevents having to deal with the issues that come with global illumination plus speeding up the render.
file_84d9ee44e457ddef7f2c4f25dc8fa865.jp
file_013d407166ec4fa56eb1e1f8cbe183b9.pn
graylensman ( ) posted Fri, 17 April 2015 at 11:48 AM
Thank you so much! I will give this a run this weekend, and let you know my results. Thanks again!
MarkBremmer ( ) posted Fri, 17 April 2015 at 11:55 AM
Sorry for the double post. Funky system today at 'Rosity. I'll delete when able.
DUDU.car ( ) posted Sun, 19 April 2015 at 4:21 AM
Mark, where do you find these light tubes ?
I use this thread to ask something I don't understand :
How works an "Anything Glow" ?
MarkBremmer ( ) posted Mon, 20 April 2015 at 8:37 AM · edited Mon, 20 April 2015 at 8:38 AM
Hi Dudu.car
It should be on your insert list.file_149e9677a5989fd342ae44213df68868.pn
There is no need to use any Anything Glows function with the tube light.
DUDU.car ( ) posted Mon, 20 April 2015 at 8:54 AM
I know this tube but it looks like a bulb in C8.
For Anything glow, my question was not in connection with that of this thread but more precisely on the function of this option.
I don't understand well how that works and had a crash of Carrara by changing the parameters.
Is there a tuto about that ?
MarkBremmer ( ) posted Mon, 20 April 2015 at 9:22 AM
In C8, the 'tube' functions alone the bulb Z access - just rotate into position and set the desired length. To create the illusion of an actual tube light illumination, Anything Glows can be applied to a Vertex cylinder object.
The Anything Glows will create a miniature bulb light at each vertex point of the object - more vertexes, more fidelity in the illumination.
Now that Indirect Lighting is available as a render option, it is preferable to use that and assign a glow shader function to an object to create illumination; in my opinion, it creates better final results than Anything Glows since individual points of light do not show up in reflected highlights on other objects in the scene.
DUDU.car ( ) posted Mon, 20 April 2015 at 9:34 AM
Thanks, I 'll play with that a little...
