In the properties tab for the light, at the bottom, where it says constant you can change to inverse linear or inverse square. Inverse square is technically correct, I use inverse linear to get a cheat effect so the image is like what we see, rather than what we would photograph. Light settings (intensities) depend on whether you are using IDL and GC. Sometimes I use 5%, sometimes 25%. I do test renders using progressive render settings.
Yeah, I'm sure it's been covered but I can't find a thread that talks about the properties settings. Specifically
Shadow Blur Radius, Shadow Samples, Shadow Min Bias.
I have it set to 30% intensity and a dark, orange-yellow color on the defuse and yellow on spec. Just not sure about the shadow settings. Any help would be greatly appreciated.
