Fri, Feb 14, 9:40 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 14 8:48 am)
Subject: point light settings for candle flame
ghostship2 ( ) posted Fri, 08 May 2015 at 10:45 AM · edited Fri, 14 February 2025 at 9:39 AM
Yeah, I'm sure it's been covered but I can't find a thread that talks about the properties settings. Specifically
Shadow Blur Radius, Shadow Samples, Shadow Min Bias.
I have it set to 30% intensity and a dark, orange-yellow color on the defuse and yellow on spec. Just not sure about the shadow settings. Any help would be greatly appreciated.
Anthanasius ( ) posted Fri, 08 May 2015 at 11:30 AM
Hi
 Dont forget to setup inverse square in the light panel
Génération mobiles Le Forum / Le Site
ghostship2 ( ) posted Fri, 08 May 2015 at 12:49 PM
Hi
I have no idea where that would be or what number I would use.
Miss Nancy ( ) posted Fri, 08 May 2015 at 2:12 PM · edited Fri, 08 May 2015 at 2:13 PM
voici:
file_0f28b5d49b3020afeecd95b4009adf4c.pn
Anthanasius ( ) posted Fri, 08 May 2015 at 7:06 PM
An exemple
file_0777d5c17d4066b82ab86dff8a46af6f.jp
Anthanasius ( ) posted Fri, 08 May 2015 at 7:07 PM
Light material
file_6974ce5ac660610b44d9b9fed0ff9548.jp
Anthanasius ( ) posted Fri, 08 May 2015 at 7:08 PM
Larger view
file_698d51a19d8a121ce581499d7b701668.jp
piersyf ( ) posted Sat, 09 May 2015 at 4:27 AM
In the properties tab for the light, at the bottom, where it says constant you can change to inverse linear or inverse square. Inverse square is technically correct, I use inverse linear to get a cheat effect so the image is like what we see, rather than what we would photograph. Light settings (intensities) depend on whether you are using IDL and GC. Sometimes I use 5%, sometimes 25%. I do test renders using progressive render settings.
file_96da2f590cd7246bbde0051047b0d6f7.jp
