Fri, Nov 22, 7:39 AM CST
Subject: Using PP2014 can anyone tell what is causing this issue re conformed cloth
rowlando ( ) posted Tue, 09 June 2015 at 7:54 PM · edited Fri, 22 November 2024 at 6:55 AM
Hi just wanted some help with fixing the issue shown in the image below re the conformed cloth item on V4.
It seems something in the joint zones, so can anyone tell where to fix this is PP2014
Cheers Rowlando
Seek what you can never loose
rowlando ( ) posted Tue, 09 June 2015 at 7:56 PM
O crap the image did not load, Ok its proborbly some size issue, will load it soon I hope.
file_e00da03b685a0dd18fb6a08af0923de0.jp
RedPhantom ( ) posted Tue, 09 June 2015 at 8:45 PM
Site Admin Online Now!
This is assuming a non-weightmapped figure.
  1. select the body part that is causing the problem and figure out if it is the bend, twist or side to side (i find it's best to work with the body part moved so you can see when the problem is fixed.)
  2. next, select that same body part on the clothes.
  3. open the joint editor and select the offending dial in the drop down menu on the window
  4. under props, select innermatsphere
  5. adjust the scales so you don't have those points.
  6. repeat for all offending joints
  7. once you do one side of the body,  select the clothing and go to figures>symmetry > right to left (if you worked on the right otherwise do left to right) and when it asks if you want to copy the joint zones say yes
Glitterati3D ( ) posted Tue, 09 June 2015 at 8:56 PM
What causes it is poor rigging.  Those issues are caused by the falloff zones not being rigged properly.  RedPhantom's instructions will help you fix them.
Is this converted clothing? The conversion process can cause those rigging issues.
rowlando ( ) posted Tue, 09 June 2015 at 9:46 PM
Hey Redphantom thanks so much, would you have a few images I could follow?
Yes I converted it in the fitting room, because I wanted the morphs added to the figure from V4, the figure did not have all the morphs I wanted.
Cheers Rowlando
Glitterati3D ( ) posted Tue, 09 June 2015 at 9:57 PM
Cheers Rowlando
Oh, you didn't have to do that.  If you want morphs in the clothing that exist in V4, it's simple......... Load V4 and inject your morphs
Load and conform the clothing
With the Clothing>Body selected on the Figure dropdown menu, go to Figure>Copy Morphs From
Select V4.
You will be presented with a list of the morphs in V4 and you can pick and choose or just transfer them all.
That's how you get the morphs in.
rowlando ( ) posted Tue, 09 June 2015 at 10:15 PM
Ok thanks, I wanted the auto conforming morphs is there something to make this happen?
NanetteTredoux ( ) posted Wed, 10 June 2015 at 12:41 AM
Load the garment and select the body.
Go to the properties tab.
There is a section there labelled "when conforming". Just tick them all.
Your garment should now behave as auto conforming.
Poser 11 Pro, Windows 10
rowlando ( ) posted Wed, 10 June 2015 at 2:58 AM
hey got it sorted, I redid what man those names are hard to remember anyways a really big thank you.
re input morphs using morph transfer then checked them to auto conform in properties, things worked great.
Thanks heeps all
