This is assuming a non-weightmapped figure.
Hey Redphantom thanks so much, would you have a few images I could follow?
Yes I converted it in the fitting room, because I wanted the morphs added to the figure from V4, the figure did not have all the morphs I wanted.
Cheers Rowlando
Oh, you didn't have to do that. If you want morphs in the clothing that exist in V4, it's simple......... Load V4 and inject your morphs
Load and conform the clothing
With the Clothing>Body selected on the Figure dropdown menu, go to Figure>Copy Morphs From
Select V4.
You will be presented with a list of the morphs in V4 and you can pick and choose or just transfer them all.
That's how you get the morphs in.
Load the garment and select the body.
Go to the properties tab.
There is a section there labelled "when conforming". Just tick them all.
Your garment should now behave as auto conforming.
Poser 11 Pro, Windows 10
Hi just wanted some help with fixing the issue shown in the image below re the conformed cloth item on V4.
It seems something in the joint zones, so can anyone tell where to fix this is PP2014
Cheers Rowlando
Seek what you can never loose
