Thu, Jan 9, 2:59 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 09 2:14 am)
Subject: Natural high and low for G2F
cole4965 ( ) posted Sun, 14 June 2015 at 8:49 PM · edited Thu, 09 January 2025 at 2:40 AM
Hi there,
i purchased Natural high and low for G2F
http://www.renderosity.com/mod/bcs/?ViewProduct=110215
I followed the instructions (pretty sure I did it right) but after loading a Genesis 2 character through DSON in PoserPro 2104. The presets show in library but nothing happens to character. Anyone experiencing the same thing? I have lots of Genesis products and load all into Poser with no issue.
Thanks
markschum ( ) posted Mon, 15 June 2015 at 9:57 AM
After loading the preset from your Pose folder did you set the dial in BODY actor of the figure ?
The read-me seems to say that the dials are loaded to the BODY actor.
hborre ( ) posted Mon, 15 June 2015 at 10:41 AM
Considering that this product has a range of multiple morphs, it would make sense to spin the dials to see results.
bhoins ( ) posted Mon, 15 June 2015 at 10:45 AM · edited Mon, 15 June 2015 at 10:45 AM
That sounds like the data directory, which contains the morphs, is in a content directory that is not mapped in Poser. (Most likely cause.)
Note the data directory should be at the same level as "Runtime" in the content directory, and that Runtime must be mapped in Poser for morphs to work.
If that is set up correctly, then the path of the Morphs within the Data Directory could also be the culprit.
cole4965 ( ) posted Mon, 15 June 2015 at 3:16 PM
Not sure what you mean 'MAPPED" in Poser. All my Genesis si in an external Runtime and works fine
