Fri, Jan 31, 3:23 AM CST
DAZ|Studio F.A.Q (Last Updated: 2025 Jan 30 6:38 pm)
Subject: Atmosphere/Volume?
DarkElegance ( ) posted Wed, 24 June 2015 at 8:13 PM · edited Sun, 26 January 2025 at 1:38 PM
Ok still fighting with it...
I went to use one of the presets the "uber volumn dust"
but all it did was give me the error message that there was an issue and to check the logs....
Is there a trick of using this?
https://www.darkelegance.co.uk/
Commission Closed till 2025
Razor42 ( ) posted Wed, 24 June 2015 at 8:15 PM
What was the error message?
DarkElegance ( ) posted Thu, 25 June 2015 at 8:19 AM
it says "there was a problem loading this preset, view logs" pretty much that.
Razor42 ( ) posted Thu, 25 June 2015 at 8:59 AM
You can access the log file through help troubleshooting log file if you haven't found it.
I've tried the shader preset and it's working okay for me, just to double check your selecting an object and surface then applying the Uber Volume dust Shader preset.
You may need to look in the log file to see what the issue is. If you can find the relevant section post it here and I can have a look for you if you would like.
RHaseltine ( ) posted Thu, 25 June 2015 at 4:35 PM
Did you have an object and surface selected?
RawArt ( ) posted Sat, 27 June 2015 at 8:18 AM
I did make a simple fog camera for IRAY if that helps
http://rawart3d.deviantart.com/art/Raw-FogCam-535959358
and here are the basic instructions for it:  http://rawart3d.deviantart.com/art/Simple-Fog-Camera-Info-535961150
Rawn
