Mon, Feb 24, 10:56 PM CST
Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 24 1:37 pm)
Subject: Poser do zbrush and back tut?
dante ( ) posted Wed, 15 July 2015 at 1:53 AM · edited Mon, 24 February 2025 at 8:14 PM
Hey guys
Are there any good tuts on working with poser figs in zbrush?...like adding detail, building stuff around them and exporting them back to poser.
Thanks and all the best
boyonamission ( ) posted Wed, 15 July 2015 at 2:06 AM
Hey!
What do you want to know exactly? if you want to build hair that is possible but you have to select the subtool( in this case hair) and than use goz to poser to get the hair mesh aligned on the model. With adding detail you can substract displacement maps and also normal maps from the high subdivided mesh and use those maps on your lower polygon mesh.
dante ( ) posted Wed, 15 July 2015 at 2:11 AM
Hey!
Yeah, but a tutorial on how to do all that without loosig the original rigging or the original UVs (if possible) would help me a lot...for instance I would like to have vascularity and scars embeded into the geometry... Thanks for answering
Cheers
boyonamission ( ) posted Wed, 15 July 2015 at 2:14 AM
The rigging won't change at all. You cant embedd into geometry without breaking the polycount, that's why you have to extract the normals and displacement maps to, fake the higher cage on a lower polygon model. There are plenty tutorials on the internet for that.
dante ( ) posted Wed, 15 July 2015 at 10:29 PM
Thanks a lot brother...I'll hunt around All the best
AmbientShade ( ) posted Wed, 15 July 2015 at 11:51 PM · edited Thu, 16 July 2015 at 12:01 AM
what version of Poser are you using?
If you have Pro 2012 or 2014/game dev, then you have a built-in Poser to Z-Brush utility called GoZ. It can be found at the bottom of the figure menu in Poser. "Export figure mesh to GoZ"
Just select the figure you want to send to z-brush and click that option in the figure menu. It's also at the bottom of the Object menu if you are working with a model that isn't rigged.
A menu will come up with a few options in it. If you want to send the figure in a specific pose, then check the box next to "Export Posed". Otherwise leave it unchecked (default) if you want the figure to go in its zero pose. (Generally you'd only export posed if you are creating JCMs).
Material is on by default. This tells Z-brush to create polygroups based on the material groups set up in the figure - useful for texturing in Z-brush. If you select by body part, then it will create polygroups based on each body part.
Once you make the changes to the figure you can send it back to Poser and everything should work fine.
If you're just using the figure as a base to build clothing around, then you can send the clothing mesh back to Poser via Z-Brush's GoZ menu. Just make sure you have Poser selected as the active GoZ app.
If you're creating texture maps, then you'll need to export them manually from Z-Brush and set them up in the material room yourself.
You can divide the mesh however many times you want. Z-Brush will retain the vert order and send the lowest res mesh back to Poser without breaking anything. The only drawback is that Poser's SubD won't use any of the sculpting you do in z-brush. But you can divide the mesh to create morphs if the base res isn't high enough for you to work with, and the low-res version of the morph will still work in Poser. (At least that is the case in 2014/GD. Haven't tested that in 2012).
*Should also note - if you close Poser or Z-brush, before sending the mesh back then the link between the two apps is broken and Poser won't recognize the returning mesh as an altered version of that figure, so it will bring the mesh back in as a static mesh - no rigging, etc. So don't close either app or change anything in your Poser scene until you're done.
GoZ isn't available in the standard versions of Poser 9 or 10. You'll need to import the figure into Z-Brush manually if you're using one of those versions.
