Tue, Feb 4, 9:30 PM CST
Subject: Color of the light
  • 1
  • 2
mdbruffy ( ) posted Thu, 13 August 2015 at 11:38 PM · edited Tue, 04 February 2025 at 9:27 PM
I have an imfitie light showing through the stained glass. But I'm getting white light on the floor. How do I get the window colors on the floor?
file_07e1cd7dca89a1678042477183b7ac3f.jp
RedPhantom ( ) posted Fri, 14 August 2015 at 11:13 AM
Site Admin Online Now!
Thaat's caustics and ATM poser can't do those. It looks like Poser 11 will, if you cam wait and afford the upgrade. Otherwise, you'll have to fake them. One thread for this is here http://www.renderosity.com/mod/forumpro/?thread_id=2695748& Look at what bagginsbill said.
Miss Nancy ( ) posted Fri, 14 August 2015 at 6:48 PM
haven't seen that one - goes back to P7. thx fr link, red.  nerd said P11 has caustics, however stain glass problem may be light thru transparency, which nerd ain't mentioned but which stefan may have added.  OP can also fake that with blurred map on spotlite at xtreme distance, narrow beam.
Miss Nancy ( ) posted Fri, 14 August 2015 at 7:51 PM · edited Fri, 14 August 2015 at 7:53 PM
it might also work with translucence.  lite has map but window is white diffuse backface with translucence<=1.
 spotlite may produce coloured atmospherics (god-rays).
mdbruffy ( ) posted Fri, 14 August 2015 at 9:30 PM
And when is Poser 11 supposed to come out? I hope it works better that 10 and 2014 did.
mdbruffy ( ) posted Fri, 14 August 2015 at 9:31 PM
All right then. I have Vue 2014. Maybe I can get it and get it to work in that.
Miss Nancy ( ) posted Mon, 17 August 2015 at 3:51 AM
 thx to OP fr question.  helps me realise how they may have set up area lites in P11.  much better than P10 diffuse emitters if I'm right.
icprncss2 ( ) posted Mon, 17 August 2015 at 5:09 AM
Try a one sided square and the windows image map one the floor.  Mask out all but the colored panes, adjust the transparency and translucence of the material.  Also experiment with light emitters on the panes.
You can also post work the caustics.
mdbruffy ( ) posted Mon, 17 August 2015 at 8:55 AM
I just broke down and took the render into photoshop.
file_ec5decca5ed3d6b8079e2e7e7bacc9f2.jpI do appreciate everyone's help, though.
Miss Nancy ( ) posted Mon, 17 August 2015 at 6:17 PM · edited Mon, 17 August 2015 at 6:18 PM
try again:
alt text
am tempted to post one in new gallery (they wiped our imgs) labelled "area lite in P10"
oops! it reversed posting time!
Miss Nancy ( ) posted Mon, 17 August 2015 at 9:51 PM
it looks great! here's one w/translucent disc in poser:
oops! can't post img w/new forum software
wait, I was wrong! they didn't wipe all galleries
plus they now gimme over an hour to edit this
Connatic ( ) posted Tue, 18 August 2015 at 9:06 PM · edited Tue, 18 August 2015 at 9:13 PM
I put the window map on the single infinite light. Had to play with the tile UV proportions and offset until the projected map matched the cast illumination and also enabled atmosphere volume.
mdbruffy ( ) posted Tue, 18 August 2015 at 9:18 PM
I will definately try that. I forgot about applying textures to the lights.
mdbruffy ( ) posted Wed, 19 August 2015 at 7:20 PM
Connatic, I'm confused. I can get the texture on the light, but I have to make it a spotlight, shrink the size of the light and practically out it on the floor to get anything close to what we're trying for. What did you mean by UV proportions and off-set? Those are things I have never dealt with.
Connatic ( ) posted Wed, 19 August 2015 at 8:45 PM
Here is a capture of the infinite light materials pane. This was an experiment for me, trying to achieve what you posted about. I had never added an image map to an infinite light other than hdr/environment types. At default with the image applied it projected multiple tiled versions. So, I decided to try changing the U and V scale and offset values, and it eventually gave me the expected result.
mdbruffy ( ) posted Wed, 19 August 2015 at 8:48 PM
I see what you're talking about now. I'll try again and see what I can do. Thanks for helping.
Connatic ( ) posted Wed, 19 August 2015 at 9:00 PM
The values in Atmosphere materials Are:
Volume On
Vol_Color = white
density= .025
stepsize= .8333
When I made the render I had unknowingly left Ambient Occlusion On for the light and it was set to .7.....The rays are still visible with it set OFF, but are somewhat less intense. The render speed without AO is much quicker. Also the light atmosphere strength = .01
mdbruffy ( ) posted Wed, 19 August 2015 at 9:10 PM
Got it. Thanks.
Connatic ( ) posted Wed, 19 August 2015 at 9:24 PM
My render has a lot of bizarre artifacts from the atmosphere. The building probably needs to be very tight at the seams to eliminate that. Possibly doing several versions of the render with various settings/combinations and then compositing as layers could get rid of the noise. Much more experimenting is needed!
mdbruffy ( ) posted Wed, 19 August 2015 at 9:35 PM
I think we're all writing the book as we go on this.
mdbruffy ( ) posted Thu, 20 August 2015 at 5:20 PM
Connatic, I used the exact same numbers you did. I guess it doesn't work in Poser 9.Tiled Light.jpg
Connatic ( ) posted Thu, 20 August 2015 at 6:17 PM
The UV scaling was relative to the size of the window in my scene. Increasing the scale made the tiled image larger, until it matched the size of the opening. Also, you do not have shadows checked. I think that might make a huge difference. I suggest experimenting without the atmosphere being active, to get the image projection to align.
mdbruffy ( ) posted Thu, 20 August 2015 at 6:31 PM
okay.
mdbruffy ( ) posted Thu, 20 August 2015 at 8:35 PM
OKay. I started with 3. I'm up to 16 and the image is still all over the model.Still not working.jpg
Connatic ( ) posted Thu, 20 August 2015 at 9:32 PM
Is the half-circle with the design a window in a wall of a building? In my render the projection is the same map which is used for a stain-glass window which is the only opening in an otherwise solid wall. The window is still a mesh with transparency. Your room looks like it has a lot more light shining, even in the stage display. In mine the non-rendered stage is very dark, no light on the opposite side of the objects facing away from the single active infinite light.
mdbruffy ( ) posted Thu, 20 August 2015 at 9:41 PM
That half circle window is at the other end of the building. This is what I'm trying for- again, this was done in photoshop.Delta shield lit up - Test.jpg
Connatic ( ) posted Thu, 20 August 2015 at 10:10 PM
I am guessing it's something about the different buildings. I have no idea why the image would be cast where direct light should not be shining.
mdbruffy ( ) posted Fri, 21 August 2015 at 3:56 AM
Ok then, I'll just have to stay with Photoshop then. I do appreciate you trying to help though.
rokket ( ) posted Fri, 21 August 2015 at 6:29 AM
What building are you using for your render, mdbruffy?
If I know what it is, perhaps I can download it and give this a try. Poser 9 and 10 both have the same basic firefly render settings (IDL, et al). I have both Poser 9 and 10 on my laptop. I can try this in both.
mdbruffy ( ) posted Fri, 21 August 2015 at 4:18 PM
rokket, I made the building for my up-coming graphic novel. It's a free download at my Deviantart gallery:
http://mdbruffy.deviantart.com/art/Collected-Starfleet-Memorial-Gardens-554247993
rokket ( ) posted Fri, 21 August 2015 at 8:01 PM
Ok, cool. I will download it and see what I can come up with.
mdbruffy ( ) posted Fri, 21 August 2015 at 8:05 PM
Okay- and thanks.
rokket ( ) posted Sat, 22 August 2015 at 10:23 PM
I tried several things but nothing really worked. But here are some things I learned from the pz2:
  1. Your render settings don't include using IDL and they should. Getting any image at all to shine of the ground as if it was coming through the window was very hard to do with all those infinite lights you had in the scene.
  2. The window that you want doesn't have a useable UV map to attach to the light. I would remap it so that you can use the image to attach to the light. OR
  3. Create a .png image of that window, but place the light just inside and pointing down at the floor and attach the image that way.
    I hope this helps.
mdbruffy ( ) posted Sun, 23 August 2015 at 6:42 AM
Okay. Thanks.
Miss Nancy ( ) posted Mon, 24 August 2015 at 1:36 PM · edited Mon, 24 August 2015 at 1:38 PM
inf lite not good for this. use spotlite. if nobody can set it up in P8/9/10, let me know. steep angle of lite not ideal. in PBR (P11), it might be more interesting, if you can get betazoids to render this for you. I asked one of 'em but "mum's the word" so far.
mdbruffy ( ) posted Mon, 24 August 2015 at 3:15 PM
Miss Nancy, the problem- on top of what we've been dealing with- is that this is for a graphic novel. Some pages would have as many as 6 renders on a page. I tried a spotlight and couldn't get it to work either.
I think we're out of luck on this until SM pulls something out of their hat.
rokket ( ) posted Mon, 24 August 2015 at 7:02 PM
One thing I would try is to take out the window and replace it with a blank. Then use texture and bump maps to mimic what you modeled. That would give you a better result.
mdbruffy ( ) posted Mon, 24 August 2015 at 7:06 PM
But then when I show that wall with the light coming through, there'd be nothing there except a hole in the wall.
rokket ( ) posted Mon, 24 August 2015 at 7:24 PM
No, you're misunderstanding what I am telling you. You model the window but not all of the internal parts. In essence, you would have a disc up there, and the stained glass would all be texture map and bump maps.
Like this: Here is the Hi-res ball
Hi-Res ball with texture and bump maps. None of the globe was modeled into the ball. It's a blank.
Miss Nancy ( ) posted Mon, 24 August 2015 at 7:42 PM · edited Mon, 24 August 2015 at 7:43 PM
try this:
don't hold your breath waiting for PP2016 to do this
YWIA
mdbruffy ( ) posted Mon, 24 August 2015 at 7:51 PM
Miss Nancy posted at 7:49PM Mon, 24 August 2015 - #4223800
try this:
YWIA
Miss Nancy, which light? I'm not clear on what you're showing me.
rokket ( ) posted Mon, 24 August 2015 at 8:16 PM
That is a spot light.
mdbruffy ( ) posted Mon, 24 August 2015 at 8:19 PM
Okay. I'll try it again. First time I couldn't get it to work.
mdbruffy ( ) posted Mon, 24 August 2015 at 8:40 PM · edited Mon, 24 August 2015 at 8:45 PM
I tried it with the exact same settings and got the same tiling effect I got before- the pattern was all over the walls. I have tried 5 tgimes now to load the image and the site will not respond and let me.I finally got it. Spotlight.jpg
rokket ( ) posted Mon, 24 August 2015 at 8:46 PM · edited Mon, 24 August 2015 at 8:48 PM
I believe you are attaching the image to an infinite light, not to a spot light.
Or you have the spot light too high in the scene.
Connatic ( ) posted Mon, 24 August 2015 at 8:54 PM
There has to be some other factor causing the light to shine on the wrong sides of the walls. Although the spotlight is undoubtedly a better choice than the infinite light, I was still able to get the texture to shine properly with an infinite light. How is that texture being tiled on the far wall? If the lightsource with the map is outside, it should not be there.
mdbruffy ( ) posted Tue, 25 August 2015 at 7:25 AM
It's splashed all over the set. Thing is, you can see where the light from the spotlight hits the floor- That's exactly where I want it.
Note to Miss Nancy: If I send you my e-mail in a private message, could you send me a copy of your scene file? If I compare EVERY setting, I might be able to figure this out.The whole set.jpg
bagginsbill ( ) posted Tue, 25 August 2015 at 10:14 AM
If you don't want the image tiled, why do you have the Image_Mapped value set to Tile?
I've waited several days to see if anybody would notice that.
mdbruffy ( ) posted Tue, 25 August 2015 at 10:26 AM
bagginsbill posted at 10:20AM Tue, 25 August 2015 - #4223969
Miss Nancy had her settings set to Tile and I set mine exactly to match.
Just tried with Alpha, None and clamped and got the same result.
bagginsbill ( ) posted Tue, 25 August 2015 at 1:04 PM · edited Tue, 25 August 2015 at 1:04 PM
There are details within details within details here.
If you're
  • using a spotlight
  • have your image map scale set to 1 in both dimensions
Then the tiling does not apply and doesn't matter what you set it to.
If however, you're trying to scale the image to less than 1 in either dimension, then the Tile parameter value does matter and will reveal a difference.
If you're doing this with an infinite, not a spotlight, then it can only tile, and ignores the image if you use anything but tile, and will show many copies across the entire "world". (As tested in in Poser Pro 2014 - not sure if this is a recent change or not)
Miss Nancy ( ) posted Tue, 25 August 2015 at 1:04 PM · edited Tue, 25 August 2015 at 1:15 PM
pz3 file (2.9 MB) won't work due on yer machine due to having 3 refs to my drive names, however I'll see if I can change it to be generic for P9.
had to extract window prop from yer scene due to large obj size (147 MB), so I could handle it quickly.
first, generate img map for spotlite using render of window surrounded by black, which I already did and can give you.
spotlite has angular falloff - compensate by large black border in img map.
window can be done many ways. one is to use fastscatter on white disk, as done in first image of spotlite with tiled img projection.
however that method requires UV-scaling at steep spotlite angle.
it's easier to just assign ambient = 1 to all colours in window, then turn off shadow-casting for window, then position spotlite with these parameters:
point at window (assuming window is facing front cam)
poser native units in prefs
angle 18
rgb 1
intensity 200
xtran 0
ytran 8
ztran 4
use img map below for spotlite
use matl room settings for spotlite as shown above
in P11 I daresay they will use something like how carrara handled stained glass.
tiling variable affects inf lite, but don't use inf lite
forum software won't allow me to attach img using markdown if there are space separators.
startrek logo
p.s. @BB: thx fr tip on spotlite. was gonna read manual someday! knew there was some way to adjust, but I recalled falloff graphs for some reason.
hey wait a tic! they deleted "mention" button, which everybody hated. next they should add "thank" button, like at rdna. those guys just updated
their software so now "thank" button appears in my browser (safari 5). now if I can just find "ignore" button at rdna to handle trolls there.
  • 1
  • 2
