Fri, Jan 31, 1:45 AM CST
DAZ|Studio F.A.Q (Last Updated: 2025 Jan 30 6:38 pm)
Subject: Mirroring an object???
DarkElegance ( ) posted Fri, 21 August 2015 at 12:43 PM · edited Thu, 30 January 2025 at 11:33 PM
Ok I made this pillar thing with drapes....but I was hoping to mirror it on either side of the scene. Now I thought there was a way to mirror an object in DS...but I cant find a way to do it.
Any suggestions?
https://www.darkelegance.co.uk/
Commission Closed till 2025
cunningf ( ) posted Fri, 21 August 2015 at 1:40 PM
If you use New Node Instance in the Create menun it makes an exact copy of the selected item which can then be moved wherever it's needed.
DarkElegance ( ) posted Fri, 21 August 2015 at 1:41 PM
will it flip it horizontal? that is what I need it to do
cunningf ( ) posted Fri, 21 August 2015 at 1:45 PM
Does setting the X & Z scale to -100% do it?
If not I'm out of ideas.
RHaseltine ( ) posted Fri, 21 August 2015 at 2:58 PM
Only set one axis to -100% - setting two axes to -100% is the same as a rotation around the third axis.
malwat ( ) posted Sat, 22 August 2015 at 5:08 PM
Not sure whether it will do what you want, but look at http://docs.daz3d.com/doku.php/artzone/pub/software/symmetry/start
Alternatiely copy the item as suggested above and change the horizontal scale (probably the X-scale) to -100% as suggested by cunningf
I am assuming DS rather than Poser....
Malwat
Getting younger by the day; getting older by the minute....
