Thu, Nov 28, 7:51 PM CST
DAZ|Studio F.A.Q (Last Updated: 2024 Nov 28 3:41 pm)
Subject: how to save a prop
lululee ( ) posted Mon, 24 August 2015 at 5:19 PM ยท edited Thu, 28 November 2024 at 5:41 PM
Hi'
I modeled a belt that is a smart prop.
I can export it into DS but how do I save it so I can include it in a set I am making.
Thanks
Cheerio
lululee
LPR001 ( ) posted Mon, 24 August 2015 at 8:47 PM
Good point because if you didn't put "Smart" in front of this I would have said save it as a Support Asset >figures/props I am not sure why you wouldn't go the same route anyway. Did you try?
- Johnny G
"Try animation to get things moving"
lpr001@renderosity.com
Bejaymac ( ) posted Tue, 25 August 2015 at 5:10 AM
Make sure it's parented to the required bone in the scene tab, and with just it selected go "File > Save as > Support asset > Figure/prop Asset", you'll then get the standard save window to create the DUF file, once that's done the Assets window will open, fill in the data and at the bottom select "smart parenting".
lululee ( ) posted Tue, 25 August 2015 at 11:27 AM
Hi,
Thanks so much for the valuable info.
It works fine saving it as the support asset with the "smart prop".
I tried to open the .duf file and it looks like something in a foreign language but everything works well.
I am used to being able to open a pp2 file and reading that to see if there is a connection to an obj file but I guess if it works all should be well.
Cheerio
lululee
Medzinatar ( ) posted Tue, 25 August 2015 at 12:55 PM
If you want a readable duf, uncheck "compress file" on save dialog.
There may be a dialog for decompressing existing files, but I just use WinRar because I find it easier
RHaseltine ( ) posted Tue, 25 August 2015 at 4:38 PM
Window>Panes(Tabs)>Batch Convert can be used for compressing/uncompressing - though I too use a zip tool, 7 Zip in my case.
lululee ( ) posted Tue, 25 August 2015 at 5:01 PM
Thanks so much for the valuable info on the decompressing.
So much to learn.
I really appreciate all the help.
Cheerio
lululee
LPR001 ( ) posted Tue, 25 August 2015 at 9:38 PM
Pleased to see you have got this sorted lululee and I look forward to seeing what you develop. You already have a great range of stunning products I just know it will be great.
- Johnny G
