DAZ|Studio F.A.Q (Last Updated: 2025 Jan 02 6:48 pm)
I am assuming that you are trying to transfer rigging from G3F (please use the proper naming to avoid confusion) to a custom made dress. Or does the dress belong to another figure? Judging from the panel settings, I would uncheck the Face Groups, you really don't need it with the dress. Take a look at Content Type at the bottom and see if there is a selection for appropriate for the clothing. Otherwise leave it blank. After rigging transfer, save the dress to your library, delete it from the scene, then reload it it G3F. Allow autofit to dress the figure. If it doesn't fit, check if there are any active morphs causing poke through. Those might need to be transferred also.
So long time no meeting here. how's everthing going?
1:only just import obj that fits
well 2:but after transfer utility,that fits
badly on left-hand. 3:does check in dialogue is
wrong? 4:what is the right way to check
in transfer utility when it is for
g3? 5:Does need setup room that can
do fit well? Any setup room tutorial is where? Thanks
