Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 16 10:02 pm)
infinity10 posted at 12:01AM Sun, 27 September 2015 - #4230986
Interesting. I wouldn't expect a true transparent object to produce specular light bounce.
It doesn't actually emit light. That effect was done with a point light right at the same place where the transparent cylinder is placed.
I've got a two-horse carriage with removable lanterns; the lanterns have a modeled flame (not a flat transmapped billboard). It also has Firefly IDL emitters so that it will cast light if rendered in P9+ with IDL engaged. The illumination output can be adjusted. There is a black iron ring at top for a handle My Poser is busy running test renders at the moment, but I can pack the lantern up later.
OSes: Win7Prox64, Win7Ultx64
Square lantern . Copyright seachnasaigh 2014. This model free for both personal and commercial renders; do not redistribute. Those holding a valid Poser Pro 2014 Game Dev license may export this model as a game asset consistent with the SmithMicro GameDev eula.
If you are using P5-P8/Pro2010, hide or delete the "emitter" props, and substitute a Poser point light. The glow aura will still work. In P9+, render with IDL engaged and the lantern will cast light; to adjust intensity, change the ambient_value of the emitter props in the advanced material room.
seachnasaigh posted at 3:46PM Sun, 27 September 2015 - #4231083
Very cool! I have to give that a try.
I stumbled on a way to make a candle flame in poser. Create a transparent cylinder and put a colored spotlight on it. That makes a specular reflection on the invisible cylinder, and if you put it in the right place it looks like a candle flame. At least it looks like a candle flame when you give it the toon treatment.
Here's the thumbnail from my gallery![gallery thumbnail](https://bw-1651cf0d2f737d7adeab84d339dbabd3-gallery.s3.amazonaws.com/images/image_2644568/thumb_f24009a76611e0a427389886c03bd7ab.png)
