Fri, Jan 3, 11:32 AM CST
DAZ|Studio F.A.Q (Last Updated: 2025 Jan 02 6:48 pm)
Subject: IRay Environment map (dome) colour rainbow in render.
kittykat98 ( ) posted Sun, 13 December 2015 at 4:18 PM ยท edited Wed, 01 January 2025 at 7:20 AM
I use any of the IBL's from HDRlabs.com and they render with a pronounced green on the right fading to blue on the left. It doesn't matter how the dome is rotated or which file I use (large jpg, or either HDR) I get the same result although the jpg is much more washed out (as expected). There's nothing in the file itself that would do this and I've carefully checked selections in the render pallet. Any suggestions?
Jack238 ( ) posted Mon, 14 December 2015 at 8:43 AM
I have noticed that too. I cannot suggest anything, but I can let you know, you are not the only one to notice that
prixat ( ) posted Mon, 14 December 2015 at 9:37 AM
Can you show an example? Any special camera settings?
regards
prixat
kittykat98 ( ) posted Mon, 14 December 2015 at 2:13 PM
Here's a small test strip (edited to protect the sleazy). It doesn't matter which one I use or which file in the IBL folder, I still get this. I'm rendering in IRay by the way. nice to hear that it's not just me.
spad007 ( ) posted Mon, 14 December 2015 at 2:57 PM
Is it Alpha channel banding? i read somewhere that i ray doesn't play well with Alpha or something. just a thought if i am wrong i am wrong. i can not get my I-ray to work right either.
kittykat98 ( ) posted Mon, 14 December 2015 at 4:13 PM
There is no alpha channel in the file but I will check if the power ever goes back on here (grumble, grumble stupid power company...1 lousy cm of ice/snow and pow! power dies.) IRay has worked brilliantly for me in Daz; certainly much better, and with far superior fabric shaders than Reality. This is the only problem I've encountered and it's hardly a show stopper.
spad007 ( ) posted Mon, 14 December 2015 at 6:04 PM
Ah maybe it needs an Alpha channel but that might not be right as jpegs don't have them. Bmp's do as does some png's maybe turn off the alpha in the surface's so I-ray won't look for one. I still might be wrong!! i just remember seeing something like this years ago fracking fog textures did something like this to me and it was the alpha at fault. regular windows paint can see and save alphas i would not think a background or dome would need a alpha...Glass etc effects do some times
Ameesa ( ) posted Tue, 15 December 2015 at 1:12 AM ยท edited Tue, 15 December 2015 at 1:19 AM
If you are using a Finite Sphere there is a setting "Visualize Finite Dome", try setting that to off. I had this problem before, but couldn't remember what I did to fix it, so just spent the last 45 minutes trying to recreate it. Turning on that setting was the only time I was able to recreate that effect so far.
Edited to add, the attached photo is the Finite Sphere set to a radius of 1.0, you can see how it gives the rainbow effect. I think it's so you have more control over the size of elements in the HDRI.
Ameesa ( ) posted Tue, 15 December 2015 at 1:26 AM ยท edited Tue, 15 December 2015 at 1:27 AM
Decided to add a couple more shots. The first is the same sphere set to 100 and the second is the sphere set to 3, with the default being 100. I could be entirely wrong, since I'm just starting out with IRAY myself, but I think it's to help identify elements in the background as you resize your sphere.
kittykat98 ( ) posted Tue, 15 December 2015 at 10:10 AM
Aha! I tried fiddling with the settings you mentioned and found that 'visualize Finite dome' was indeed the culprit. It's a shame that there's no guide or manual for IRay but then, Daz never has given folks any information on their software. That's why I don't support them. Thanks again for the info.
Ameesa ( ) posted Tue, 15 December 2015 at 10:25 AM
I'm sorry, but the comment about DAZ was unnecessary. From what I read, other new renderers are also not well documented, and remarks like that only fuel the app war. You asked for help, help was given. Fortunately , others may also benefit.
kittykat98 ( ) posted Tue, 15 December 2015 at 10:52 AM
The comment about Daz was absolutely necessary. Reality comes with a comprehensive manual. Poser (and it's various renderers) comes with a complete manual. IRay in 3DSMax comes with a manual, VRay is insanely well documented. Cycles (in Blender) has a million tutorial videos. All Adobe apps come with access to a massive online manual and guide. Daz needs top have their failings repeatedly rubbed in their face in the hope that they do something about it. Constantly being reminded about their lack of any meaningful instructional material will hopefully persuade them to provide some, and let new folks know what they're getting into. It shouldn't be up to users to write their documentation.
Ameesa ( ) posted Tue, 15 December 2015 at 1:25 PM
FYI, it is documented. I just never really bother to look. I can't really blame DAZ for that. http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/interface/panes/render_settings/engine/nvidia_iray/environment/start
Jack238 ( ) posted Tue, 15 December 2015 at 3:02 PM
Thank you, that was the situation with my render also.
kittykat98 ( ) posted Tue, 15 December 2015 at 3:20 PM
Ameesa posted at 3:16PM Tue, 15 December 2015 - #4244350
Wow! I beg and plead in the Daz forums for a manual/FAQ/guide or a note tied to a brick and thrown through my window and get nothing. How the stink did you find this? Are they keeping it a secret? I gave up checking the Daz wiki as there where no updates other than listing the headers.
Ameesa ( ) posted Tue, 15 December 2015 at 3:45 PM
To be completely honest I googled DAZ Studio finite sphere settings or some such first, and that took me right where I needed to go. However, for future reference and for anyone else who may need it, below is the landing page for the DAZ Documentation Center.
http://docs.daz3d.com/doku.php/start
kittykat98 ( ) posted Wed, 16 December 2015 at 4:23 PM
I shouldn't have gotten too excited. That was just about the only complete page and there's been no updates since I last checked it a few months ago. At least the shader system has numerous tutorials floating around. I've been able to make some decent fabrics for my own use. Thanks again for the link.
