Sun, Jan 5, 10:31 AM CST
DAZ|Studio F.A.Q (Last Updated: 2025 Jan 02 6:48 pm)
Subject: Using G3F morphs with G3M...
LadyGodiva ( ) posted Thu, 07 January 2016 at 3:09 PM · edited Sun, 05 January 2025 at 10:28 AM
Please forgive me if this question has been asked before. is it possible to use a G3F morph with G3M?
For Genesis 2, the vertex counts are the same, and I can load one exported OBJ as a morph for the other. G3M has a slightly different vertex count than G3F.
Is there a technique ( inside DAZ studio or otherwise ) to transfer a morph?
Thanks in advance, LadyGodiva
Male_M3dia ( ) posted Thu, 07 January 2016 at 3:41 PM
You would use the transfer tool to copy the morph from G3F to G3M using the G3F clone. Note that the geometry in the chest area is different so you may need to clean up that area with an external modeller.
LadyGodiva ( ) posted Fri, 08 January 2016 at 12:38 PM · edited Fri, 08 January 2016 at 12:39 PM
Thank you so much for your response.
I fear that I may be doing something wrong. When I use the transfer utility, either nothing happens, or it eats up all 12 GB of my ram and needs to be force restarted. I'm sure a parameter tweak or two will do the job. Here is a screenshot of one of my attempts. The morph I want to transfer for this test is called "BigHead". This is just a test morph of course.
If anyone could give me a hint as to what combination of parameters I need to transfer a morph ( can transfer all of them, but I'll only need one in the end ), I would be most appreciative :D
It would be even more helpful if a screenshot was provided :D :D :D
LadyGodiva
Male_M3dia ( ) posted Fri, 08 January 2016 at 12:41 PM
I think you can set the morphs you want to transfer as a favorite then on the screen you have shown, select "morph target" and on the "extended options" there should be an option to transfer only favorites.
LadyGodiva ( ) posted Fri, 08 January 2016 at 1:35 PM
Ah ha! That was it. It didn't turn out quite right, but I'll dabble with it for a while. Thank you so much!
LadyGodiva ( ) posted Fri, 08 January 2016 at 1:47 PM
Ok, I figured out the exact procedure for doing it. Here is the screenshot in case anyone else was having trouble with this issue.
Thanks again!!! LadyGodiva
Jack238 ( ) posted Mon, 11 January 2016 at 6:36 PM
Thanks for posting the solution. I know I will find it helpful. Jack
