DAZ|Studio F.A.Q (Last Updated: 2025 Jan 19 2:48 pm)
Thank you so much for your response.
I fear that I may be doing something wrong. When I use the transfer utility, either nothing happens, or it eats up all 12 GB of my ram and needs to be force restarted. I'm sure a parameter tweak or two will do the job. Here is a screenshot of one of my attempts. The morph I want to transfer for this test is called "BigHead". This is just a test morph of course.
If anyone could give me a hint as to what combination of parameters I need to transfer a morph ( can transfer all of them, but I'll only need one in the end ), I would be most appreciative :D
It would be even more helpful if a screenshot was provided :D :D :D
LadyGodiva
Please forgive me if this question has been asked before. is it possible to use a G3F morph with G3M?
For Genesis 2, the vertex counts are the same, and I can load one exported OBJ as a morph for the other. G3M has a slightly different vertex count than G3F.
Is there a technique ( inside DAZ studio or otherwise ) to transfer a morph?
Thanks in advance, LadyGodiva
