DAZ|Studio F.A.Q (Last Updated: 2025 Jan 02 6:48 pm)
Blender = Mix (under Mathematical. Alpha is the equivalent of Blending, Base the equivalent of Input 1 and Layer the Equivalent of Input 2.
FBM I'm not sure if there is a direct equivalent, but the enries under textures would be the most likely place to look.
The DS Default Material is optional - it's a single brick that encapsulates the DAZ Default shader, so the settings more-or-less match that. You can however dispense with it and handle your own integration of diffuse, specular, translucency etc. to give final colour and opacity values for the pixel.
Yes, displacement has its own root brick, though bricks can if necessary send output to multiple roots, so you don't need to double-up common elements.
Remember that all of this applies to 3Delight, not Iray.
RHaseltine posted at 2:44PM Tue, 26 April 2016 - #4266866
Thank you so much for that information!
ojitos posted at 10:25PM Tue, 26 April 2016 - #4266887
hello help this product works in DAZ studios ???? Thank you ,,, Real Small Room
The product page says "Not tested in Daz Studio". According to the Readme, it contains Poser files, so it should work in Daz Studio too, but it's not guaranteed to.
Jeff
Renderosity Senior Moderator
Hablo español
Ich spreche Deutsch
Je parle français
Mi parolas Esperanton. Ĉu vi?
Hi Guys,
I am working in the Shader Mixer in Daz Studio and am still learning the equivalent nodes from Poser to the Daz bricks.
I have been able to find a good amount of the bricks for my grass texture which in Poser is like this image.
The ones that are eluding me are as follows and it would be fantastic,
if someone here could tell me Apples to Oranges what it equal to what.
Blender Node in Poser = in Daz
fBm in Poser = in Daz
Also where do I tie in the displacement bricks? It seems to be completely separate from the DS Default Material
Also is the DS Default Material brick the = to the PoserSurface node?
Sorry for the nube questions, but I have a really sever case of Attention Deficit Disorder which is a learning disorder.
Regards, Tom
