Sun, Jan 5, 10:42 AM CST
Subject: Coulld someone make a lo-res version of the Eve/Dina/Vicky figures, please
saxon ( ) posted Wed, 10 October 2001 at 5:01 AM ยท edited Fri, 03 January 2025 at 2:52 PM
The lo-res default supplied in Poser no longer works for this fugure type. Daz were going to make one, but seem to have given up. There are so few of us animators it probably wouldn't be commercially viable, but it would be a great freebie contribution. It could probably be scaled via the pose library to fit all the various versions of the Eve joint format.
PhilC ( ) posted Wed, 10 October 2001 at 5:58 AM
How many polygons had you in mind?
saxon ( ) posted Wed, 10 October 2001 at 7:42 AM
Hi Phil, I was thinking in terms of fewest possible polygons. Animation is much, much easier if it can be done in real time and for interactions between two or more figures it's pretty much essential. Using lo-res figures enables this method. It doesn't have to be pretty, or have any morphs attached just a representation of the Eve type of figure. In essence, just a place-holder for roughing out an animation. Once the animation is roughed out, it's a simple matter to substitute the higher res figure and do the finer details. This is how I've been doing my animations for a long time, when Eve came out she drifted a little, but the method still worked. With the advent of Vicky and now Dina the advantages of the method are outweighed by the subsequent work involved.
PhilC ( ) posted Wed, 10 October 2001 at 8:00 AM
Try this:-- Substitute each body part with the cube prop scaled to fit.
  • Either replace body part with prop, or
  • Name the cubes to match their body part and export all as one OBJ
  • Edit the figure CR2 to point to the OBJ made up of cubes.
That's the "bones" of the idea. You'll need to flesh out some details.
saxon ( ) posted Wed, 10 October 2001 at 2:22 PM
OK, I'll try, I'll probably screw it up but, I'll try. Thanks.....
