Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Nov 13 12:50 am)
While you could edit the init values of those bend dials in your cr2 so it comes into your scene correctly, you'd still have to manually adjust the sleeves after each pose. Instead, I would pose your Jacket so that it fits your figure in the default position and then export a new .obj of your jacket. Re-point your cr2 to the new .obj, and you should be fine. Hope this helps.
i have a jacket that every time i pose the figure i need to bend the forearms to 6 (left) and -6 (right) to make the sleeves fit the figure....is there a way i can edit the cr2 to permanently keep this value?, thanks.........Steve
