Fri, Nov 29, 2:18 AM CST
Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Nov 13 12:50 am)
Subject: bend values
steveshanks ( ) posted Wed, 10 October 2001 at 2:02 PM ยท edited Fri, 15 November 2024 at 2:09 AM
i have a jacket that every time i pose the figure i need to bend the forearms to 6 (left) and -6 (right) to make the sleeves fit the figure....is there a way i can edit the cr2 to permanently keep this value?, thanks.........Steve
JKeller ( ) posted Wed, 10 October 2001 at 2:32 PM
While you could edit the init values of those bend dials in your cr2 so it comes into your scene correctly, you'd still have to manually adjust the sleeves after each pose. Instead, I would pose your Jacket so that it fits your figure in the default position and then export a new .obj of your jacket. Re-point your cr2 to the new .obj, and you should be fine. Hope this helps.
chromecafe ( ) posted Wed, 10 October 2001 at 2:41 PM
wouldnt the centre points be easier moved?
JKeller ( ) posted Wed, 10 October 2001 at 2:53 PM
Hmmm... maybe. I assumed from the question that if the sleaves needed to be adjusted by the same value to fit any pose than they didn't fit the figure in the default pose either. More information needed I guess.
steveshanks ( ) posted Wed, 10 October 2001 at 2:54 PM
Nope ;o( after conforming it still needs bending back by 6...i'm sure i read somwhere how to do this but i'm stumped where......thanks for trying though ;o).......Steve
JKeller ( ) posted Wed, 10 October 2001 at 2:56 PM
Oh wait... now this is sounding familiar. Did you "borrow" the cr2 from the base figure to create the cr2 for the jacket?
steveshanks ( ) posted Wed, 10 October 2001 at 3:05 PM
oh it doesn't fit in the default pose either....the end of the sleeves is to far back....nope i made it with pro pack by adding the teeshirt cr2 from the PT DAZ kid.....nope Chromecafe if i move those it moves the whole forearm back i just need a small bend on it .....Steve
JKeller ( ) posted Wed, 10 October 2001 at 3:14 PM
Hmmm... maybe not what I was thinking then. I'm kinda stabbing in the dark here, but does your jacket have 'phantom' rHand and lHand body parts in the cr2 or do they end with the ForeArm?
steveshanks ( ) posted Wed, 10 October 2001 at 3:17 PM
Chromecafe it worked!!! yehhaa ;o) i moved the red one and pop in it went ..i tryed that eariler with no succes LOL...thanks everyone for the help.....Steve
steveshanks ( ) posted Wed, 10 October 2001 at 3:19 PM
i tryed adding hand bones but it sent it scatty LOL anyway all fixed we must have been typing at the same time :o)...thanks, Steve
JKeller ( ) posted Wed, 10 October 2001 at 3:22 PM
Glad you got it working =)
