Sun, Jan 5, 7:12 AM CST
Subject: Gaps in texture map
offrench ( ) posted Thu, 02 June 2016 at 3:32 PM · edited Fri, 03 January 2025 at 8:03 AM
Hello all,
I have a strange problem on some models I am working on. My workflow is the following one:
  • model in Hexagon
  • auto mapping in 3dCoat
  • texture making in Hexagon
  • export in .obj format
  • import in Poser Pro 2014
In Poser, the models exported from 3dCoat have small gaps in their texture maps. They are very visible in the preview gaps-preview.jpg
When rendered (simply making CTRL+R), they are slightly less visible, but still appear gaps-render.jpg
When rendered in Octane Render (Poser Plugin), they disappear nogaps-octane.jpg
I suppose this is a Poser bug. Have you ever seen this?
Fantasy pictures, free 3d models, 3d tutorials and seamless textures on Virtual Lands.
SamTherapy ( ) posted Thu, 02 June 2016 at 3:58 PM
It's not a bug, it's a coughbullshitcough feature. Well known. You can faff around with filtering (and, I believe gamma correction) to take care of it. Most poser content creators usually go over the lines on a UV template to avoid it.
Almost none of us care about the Preview, since it's just a rough guide to how the finished thing will appear, although some poor souls use the preview for finished work, though why you'd want to do that is beyond me.
offrench ( ) posted Fri, 03 June 2016 at 12:42 AM
Thanks for the hint! After messing around a bit, I found a solution in 3d Coat. When exporting an object, there is an option at the bottom of the dialog box named: create padding. It fills all the gaps between the texture islands. This solves the problem.
RorrKonn ( ) posted Fri, 03 June 2016 at 1:43 AM
SamTherapy posted at 2:42AM Fri, 03 June 2016 - #4271250
To use preview as a realtime render engine n not having to wait 3 days on a render ;)
icprncss2 ( ) posted Fri, 03 June 2016 at 10:43 PM
Lowering the minimum shader rate in the render settings can get rid of white lines and gaps in texture mapping.
