Sun, Feb 9, 9:05 AM CST
Subject: Remember the taper scaling tool?
MistyLaraCarrara ( ) posted Thu, 14 July 2016 at 9:22 AM · edited Sun, 09 February 2025 at 9:02 AM
early Poser days. the meat and potatoes of poser domme. 👏
the days before internet activation. figures turned into boxes when posing.
geep ( ) posted Thu, 14 July 2016 at 9:26 AM · edited Thu, 14 July 2016 at 9:27 AM
... and ?
cheers,
dr geep ... :o]
edited 10/5/2019
MistyLaraCarrara ( ) posted Thu, 14 July 2016 at 10:31 AM
no knows what the rules are naos to make the taper scaling work in pp12 👃
icprncss2 ( ) posted Thu, 14 July 2016 at 10:56 AM
It's been a long time since I used P4/PPP. I don't recall if the taper and scale tools were a combined tool or if they were separate tools back then. I do know that P5 and up has the scale tool and taper tool as two separate tools in the tool pane. They allow you to either taper or scale a selected figure, body part or prop along the camera's X or Y axis. There should be no reason the tools don't work in 2012. One, do you have the correct tool selected in the tool pane? Two, do you have a selected figure, prop or body part? Three, are you certain you are tapering or scaling along either the X or Y axis of the camera you are using?
EarthCrone ( ) posted Thu, 14 July 2016 at 11:40 AM
I can't answer the question whether the will work or not. But I do remember the taper tool and used it often!
"Imagination is more important than knowledge" Albert Einstein
Boni ( ) posted Thu, 14 July 2016 at 1:48 PM
A scattered variety of objects still use it.
Boni
Cage ( ) posted Thu, 14 July 2016 at 4:25 PM · edited Thu, 14 July 2016 at 4:26 PM
If you need a taper dial on an actor which doesn't have one, it can be inserted into a cr2 or pz3, using a cr2 editor. Example follows:
taperY taper { name taper initValue 0 hidden 0 enabled 1 forceLimits 0 min -100000 max 100000 trackingScale 0.04 keys { static 0 k 0 0 } interpStyleLocked 0 }
Add the above block to the Channels section of the actor to which you wish to add the dial. The "taperY" listing can be edited to "taperX" or "taperZ" according to need.
Edit: I don't know why the hell I expected Rosity to permit me to post a section from a cr2. Of course it won't do that. Rosity never does anything, anymore. Feh.
MistyLaraCarrara ( ) posted Fri, 15 July 2016 at 11:43 AM
Thanks Cage!
I love cr2 hacks. Sometimes it's the only way to go. 😯
Luved that old P5 secrets book. It showed dynamic cloth shrink wrapping 😀
pikesPit ( ) posted Fri, 15 July 2016 at 11:44 AM · edited Fri, 15 July 2016 at 11:48 AM
taperY yTaper
    name Taper Vertical
    initValue 0
    hidden 0
    enabled 1
    forceLimits 0
    min -100000
    max 100000
    trackingScale 0.004
    keys
        static  0
        k  0  0
    interpStyleLocked 0
taperZ zTaper
    name Taper Z
    initValue 0
    hidden 0
    enabled 1
    forceLimits 0
    min -100000
    max 100000
    trackingScale 0.004
    keys
        static  0
        k  0  0
    interpStyleLocked 0
taperX xTaper
    name Taper X
    initValue 0
    hidden 0
    enabled 1
    forceLimits 0
    min -100000
    max 100000
    trackingScale 0.004
    keys
        static  0
        k  0  0
    interpStyleLocked 0
Cage, use the "Preformatted Text </>" button, or insert three dots on top and below the code.
Cage ( ) posted Fri, 15 July 2016 at 2:29 PM
Okay, that helps. Thanks, PikesPit. Rosity keeps changing its text-formatting, and I had no idea what that button was for. Never would have guessed. But it is useful, a very good thing to have.
My apologies to Renderosity. Cage didn't understand these new-fangled ways of doing things and he jumped straight to wanting the Good Old Days back.
