Sun, Nov 24, 1:30 PM CST
Subject: Very promising new Poser figure BETA by Ali
-Timberwolf- ( ) posted Sun, 07 August 2016 at 5:32 PM · edited Sun, 24 November 2024 at 1:25 PM
http://www.mankahoo.com/index.php?l=product_detail&p=37# You have to be logged in to see it.
quietrob ( ) posted Sun, 07 August 2016 at 7:51 PM
It looks like Ali's personal site and is packed with lots of stuff. I didn't need to be logged in.
Ali is one of my favorite vendors, it's good to see what that fertile mind has come up with!
Kalypso ( ) posted Mon, 08 August 2016 at 1:54 AM · edited Mon, 08 August 2016 at 1:54 AM
Site Admin
Oooh I love getting new things - we Poser users are not used to them as of late. :) Thanks for the heads-up Timberwolf. Here's my version of Bella, Bella Donna.
wolf359 ( ) posted Mon, 08 August 2016 at 8:17 AM
Actually pretty decent for freebie does this work with the fitting room??
My website
SamTherapy ( ) posted Mon, 08 August 2016 at 8:23 AM
"You have to be logged in to see it."
Oh no you don't. :)
Thanks for the heads up; I love Ali's stuff.
-Timberwolf- ( ) posted Mon, 08 August 2016 at 9:18 AM
wolf359 posted at 4:05PM Mon, 08 August 2016 - #4279106
Oh, renember, its a beta. The finished product will be at a charge - i guess. As I played with it, Bella seems to have a good JCM system. Her bendings look nice. I do like her smile. It is a obviousley a big problem to let a figure smile nicley, but Ali is good at it. I've allways liked his Angela figures, that also used to bend well because of a decent JCM setting. Mimics have also been one of the strong features by Ali. I would have done improvements to Bella's default shape: Her scull looks to small and make her ears look to big. A slightley bigger skull would fit better to her body. Her knees appear to be to bulky. Her body shapy is well done though. Bummer no additional groups, like pelvis or upper chest. However, I like this beta Bella. Way better even now, than Pauline will ever be. Looking foreward to the finished product.
Kalypso ( ) posted Mon, 08 August 2016 at 9:21 AM
Site Admin
I think the fitting room works with all figures, it's not like the face room. Can't say for sure though because I just used a dynamic dress.
wolf359 ( ) posted Mon, 08 August 2016 at 9:25 AM
Well the Figure is compatible with Standard Poser Figure motion Data, I created a quick walk Cycle for her using Iclone Pro
https://www.youtube.com/watch?v=d0bQQA-E8dw
For those interested here is a link to a 300 frame animated pose file( Pz2) of the walk in the video: Enjoy
https://drive.google.com/open?id=0B2TYEp536iB8ZVdGdnI2VVIyVFk
My website
tonyvilters ( ) posted Mon, 08 August 2016 at 10:03 AM
Oh, dear, where can we give feedback.... => Ah, I just see, I hope they read their "contact" mails.
  • Not symmetrical
  • 1670+ loose vertex in the mesh. (I fear all verts at all welds have an unused double.)
  • Yet, it is not a figure but a collection of loose groups. See the above.
  • Victim of a weightmap bug.
  • Aj, multiple rigging issues.
I am gonna stop here, and send them a feedback mail this evening. => I hope they read it.
Euh, yes the fitting room can use all "PROPERLY WELDED figures".
Not sure about this collection of loose groups, and some verts, combined with the way the rigging was done, will certainly destroy "close fitting" clothes.
3DFineries ( ) posted Mon, 08 August 2016 at 1:30 PM
Figure does look promising. Tony, as far as symmetry, humans aren't symmetrical to begin with. I think it adds to the realism when a figure isn't either. Just my humble opinion.
Have a creative day!
My Lil' Store
tonyvilters ( ) posted Mon, 08 August 2016 at 1:39 PM
I send this feedback on their site.
I downloaded and tested Bella-Beta. PS ; I am a beta tester for Smith Micro Poser
So far I found :
  • The obj file is not symmetrical. About 300 vertex pairs are not symmetrical.
  • All groups are unwelded in the obj file.
  • And all vertex at all welds have a double. You have 1639 doubles. (All verts at all welds have a double.)
  • The weightmap painting also has different weights on the double vertex at all welds. Mostly visible in the Shoulders when bend.
  • The weightmaps and the bulge maps are fighting each other. => Also in the collar-shoulder area.
REMARK : Did you use the obj file that Poser exported for you from the setup-room? Because these obj files do NOT work, and always have to be replaced by externally build and properly grouped and welded obj files.
Poser only saves out individual groups, and uses its internal rewelding system to reweld the groups to a single figure at import when you load the cr2.
This would explain that the figure is not symmetrical any more, (Poser also adds a slight shift in X at obj file safe), that all groups are unwelded and that you have 1639 double vertex in the figure.
If required, I can make a video with my findings, or send screengrabs if you provide an e-mail address.
Best regards, Tony
tonyvilters ( ) posted Mon, 08 August 2016 at 1:44 PM
@ 3DFineries
In this case the obj file is supposed to be symmetrical, but it is not, because they used a Poser exported obj file that causes all their trouble. => Including the weightmap fighting that they had to apply to cover the double vertex at welds.
Poser is UNABLE to export a properly grouped and welded figure.
  • Not from wavefront obj export
  • Not from the setup room
  • Not from the fitting room (that uses the same code as the setup room.
It only exports loose groups and uses its internal rewelding system to "reconstruct" the figure at import.
-Timberwolf- ( ) posted Mon, 08 August 2016 at 1:46 PM
3DFineries posted at 8:43PM Mon, 08 August 2016 - #4279172
It doesn't matter that much, that the figure is asymetrical. It is about the mesh, that has to be symetrical. Tony, how do you make those loose vertices visable?
3DFineries ( ) posted Mon, 08 August 2016 at 2:08 PM
See I learn something new everyday! Thanks for that info. Will keep that in mind if I ever need it.
My Lil' Store
tonyvilters ( ) posted Mon, 08 August 2016 at 2:28 PM
Some screengrabs.
the collar bend back. There is a vertex out of order at each arrowtip. This pulls the group outline for the collar away from the actual weld. Bella-collar-back.jpg
tonyvilters ( ) posted Mon, 08 August 2016 at 2:30 PM
This is the waist group bend backwards some 20° See the single vertex in the middle being pulled out of alignment?? Again visible if you look at the groupoutline, and compare this with the group outline of the hip that is still at the weld.
tonyvilters ( ) posted Mon, 08 August 2016 at 2:31 PM
Bella shoulders down. Again multiple verts (that should all be at the weld line) are pulled out of alignment when the shoulders bend down.. bella-shoulder-down.jpg
tonyvilters ( ) posted Mon, 08 August 2016 at 2:43 PM
in Blender, you can pull all groups out without deformations because they are not welded.
This is impossible with a properly grouped and welded figure. So, LOL, the image below is what is NOT supposed to happen. LOL.Bella-Blender.jpg
tonyvilters ( ) posted Mon, 08 August 2016 at 2:47 PM
But???
The above is a clear example of how Poser saves its OWN object files, because Poser counts on its onw "rewelding when importing code" to reweld the figure in the viewport.
Yeah, i have to make a video about this too.
tonyvilters ( ) posted Mon, 08 August 2016 at 3:05 PM
Oh, so sorry, I forgot.
Sharp edges in the lower lashes an the elbow-tips. => See the blue line in the lower lashes?
-Timberwolf- ( ) posted Mon, 08 August 2016 at 3:29 PM
Ah yes, now I see it. Thank you Tony.
tonyvilters ( ) posted Tue, 09 August 2016 at 3:53 AM
The GOOD news:
  • First of all I really like the meshflow. A Job well done.
  • Secondly, some nice options used on the eyes and the Jaw.
  • I see a lot of morphs in the making. NICE !
  • And Ali contacted me back, so we can communicate and improve this beta to a very nice figure.
Did I say I really like the mesh? This is gonna be a good figure when finished.
-Timberwolf- ( ) posted Tue, 09 August 2016 at 4:58 AM · edited Tue, 09 August 2016 at 4:58 AM
tonyvilters posted at 11:52AM Tue, 09 August 2016 - #4279242
The GOOD news:
i feel a little bit sorry for him. To clean up the mesh he had to redo all the JCMs, right? That will throw him back a lot. See, those are the cases, where Poser makes you rip off your hair. and yes, it's gonna be a very good figure.
FVerbaas ( ) posted Tue, 09 August 2016 at 2:57 PM · edited Tue, 09 August 2016 at 2:58 PM
Forum Coordinator
First practical tries are good. She made her way into Marvelous Designer all righ and slipped on some garments of the other girls. bella_001.png
LaurieA ( ) posted Tue, 09 August 2016 at 3:26 PM
That looks awesome Kalypso, like usual ;)
wolf359 ( ) posted Tue, 09 August 2016 at 5:09 PM
Mesh issues aside, this model looks so much more like an actual human being than"Pauline"
My website
EClark1894 ( ) posted Tue, 09 August 2016 at 6:09 PM · edited Tue, 09 August 2016 at 6:13 PM
That face and that outfit kind of reminds me of Shakira's "Hips Don't lie". But... let me save you a lot of work. She could be the best looking figure on the planet and look and work absolutely perfectly, but if she don't have that support network needed, she'll just end up on the pile with the rest of them. I'm not saying don't try, I'm saying get vendors behind you who will help support her from day one.
LaurieA ( ) posted Tue, 09 August 2016 at 6:38 PM
I tried to make as much stuff as I could for his Angela figure, but it never caught on. Not sure how this one will do.
wolf359 ( ) posted Tue, 09 August 2016 at 8:03 PM · edited Tue, 09 August 2016 at 8:04 PM
"She could be the best looking figure on the planet and look and work absolutely perfectly, but if she don't have that support network needed, she'll just end up on the pile with the rest of them."
I predict a more than 90 percent probability that the above is her exact fate. She offers nothing over V4 even after all of Tony Vilters Corrections to the mesh.
But alas she could be a nice temporary distraction for some seeking something new to explore She sure takes Standard poser animation data like she was born to it.
My website
JVRenderer ( ) posted Tue, 09 August 2016 at 11:28 PM
Bella.jpg Right out off the beta wrapper.
Software: Daz Studio 4.15,  Photoshop CC, Zbrush 2022, Blender 3.3, Silo 2.3, Filter Forge 4. Marvelous Designer 7
Hardware: self built Intel Core i7 8086K, 64GB RAM,  RTX 3090 .
My Gallery  My Other Gallery
-Timberwolf- ( ) posted Wed, 10 August 2016 at 4:59 AM
wolf359 posted at 11:50AM Wed, 10 August 2016 - #4279371
There is nothing much to loose. In my case I don't use Poser anymore, because there isn't any on top of the times usable figure out there for me. Pauline is a fail, PE is delayed and nothing more yet about Venus and Orion. So we have Bella with some serious mesh issues, but looking very good right out of the beta-box. Most important at all: she bends better than any other poser figure.
RorrKonn ( ) posted Thu, 11 August 2016 at 1:51 AM
Why hasn't there been a lot of talk about Mankahoos Ang2.1 ? She looks good also.
EClark1894 ( ) posted Thu, 11 August 2016 at 5:16 AM
I've seen the same or nearly the same pose twice. I want to see some evidence that she bends as well as you say.
-Timberwolf- ( ) posted Thu, 11 August 2016 at 6:31 AM
EClark1894 posted at 1:29PM Thu, 11 August 2016 - #4279560
yup sorry, don't trust me, but better go test her yourself. No subscribtion needed and the beta is free: http://www.mankahoo.com/index.php?l=product_detail&p=37
EClark1894 ( ) posted Thu, 11 August 2016 at 6:35 AM
-Timberwolf- posted at 7:33AM Thu, 11 August 2016 - #4279565
I didn't say I trusted you or not. But if you don't want to show me , no prob.
Kalypso ( ) posted Thu, 11 August 2016 at 3:37 PM · edited Thu, 11 August 2016 at 3:40 PM
Site Admin
Here are some other poses. If anything looks way off it's probably me and my posing since I didn't use any reference. I must say I don't really fancy those bulges on the inner thighs at just above the knee. In the third image I scaled the head larger and also tried to give her a thinner waistline, again just by scaling.
@Laurie Wow, thank you!
RorrKonn ( ) posted Thu, 11 August 2016 at 10:43 PM
I think she bends well
erogenesis ( ) posted Fri, 12 August 2016 at 10:08 AM · edited Fri, 12 August 2016 at 10:08 AM
Well she certainly looks tonnes better than pauline. This figure looks very very good actually! I'm very happy to see that someone else is also making a Poser figure. Now I'm just worried that PE might be too complex lol!
"The fool is not the one that does something foolish, but the one that does nothing at all."
-Timberwolf- ( ) posted Fri, 12 August 2016 at 10:20 AM
erogenesis posted at 5:19PM Fri, 12 August 2016 - #4279716
Haha, don't worry. We do need something complex ;-)
EClark1894 ( ) posted Fri, 12 August 2016 at 2:12 PM
Looks good, Kalypso. Thanks. I'm not really an Ingenue fan though I do want that bodytype. Guess he hasn't gotten around to morphs yet. That's one of the things about Project E that doesn't have me as excited as everyone else seems to be.
erogenesis ( ) posted Sat, 13 August 2016 at 1:51 AM
what's Ingenue?
RorrKonn ( ) posted Sat, 13 August 2016 at 2:05 AM
erogenesis posted at 3:04AM Sat, 13 August 2016 - #4279781
what's Ingenue?
Googles definition
"an innocent or unsophisticated young woman."
erogenesis ( ) posted Sat, 13 August 2016 at 2:11 AM
RorrKonn posted at 9:11AM Sat, 13 August 2016 - #4279782
yeah that's definitely not my thing lol
EClark1894 ( ) posted Sat, 13 August 2016 at 9:37 AM · edited Sat, 13 August 2016 at 9:39 AM
erogenesis posted at 10:34AM Sat, 13 August 2016 - #4279783
Think porn star Riley Reid. That's the type of chrcter she tends to "portray". Riley.jpg
Look somewhat familiar now?
erogenesis ( ) posted Sat, 13 August 2016 at 11:01 AM · edited Sat, 13 August 2016 at 11:07 AM
yeah I'm more for the "entirely guilty and sophisticated" porn star type ;)
SamTherapy ( ) posted Sat, 13 August 2016 at 7:15 PM
I really, really hope your figure works in Pro 2012, ero. Looks bloody marvellous.
FVerbaas ( ) posted Sun, 18 September 2016 at 4:47 PM
Forum Coordinator
Just for the record: there is an updated version (beta 080) for download now. Not sure what has changed but it works well. One thing I noted was that the UV mapping of the body was updated. Not grossly but merely a relaxation of the mesh. I found it because I use adapted texture maps, the red bikini is quite disrupting when working on clothing, and I had black edges appearing around the upper torso. The templates are not yet updated and are still the ones that came with version beta076.
FVerbaas ( ) posted Mon, 19 September 2016 at 11:21 AM
Forum Coordinator
and follow-up: the templates on the Mankahoo-site are now updated also to meet the 080 version (filename is same but timestamp in .zip 19-09-2016)
