Sun, Feb 16, 10:57 AM CST
DAZ|Studio F.A.Q (Last Updated: 2025 Feb 12 6:12 pm)
Subject: Really Dark Iray Renders
jojo8026 ( ) posted Mon, 26 September 2016 at 3:24 PM · edited Fri, 14 February 2025 at 3:49 PM
So all my Iray renders are coming out really dark using an HDRI from Dimension Theory, how do I fix this, do I change the exposure and if so what are some good settings for outdoor scenes, Ive taken photography classes for my degree but I still have trouble understanding what does what and what works well. Here are my settings I am using right now Snip20160926_2.pngSnip20160926_3.png
GKDantas ( ) posted Mon, 26 September 2016 at 5:03 PM
Can you post a thumb from the HDRI? Its looks very dark, so you can try to increase the environment intensity to 4 or more
Follow me at euQfiz Digital
jojo8026 ( ) posted Mon, 26 September 2016 at 5:18 PM
and Ive done that and it doesn't help, when I start rendering its completely black, you would think you would be able to see atleast something
GKDantas ( ) posted Mon, 26 September 2016 at 5:46 PM
The render is right, try to disable the Draw Dome thing and try this HDRI with a simple cube to see if its working. I dont have this one. If didnt work, try to re install the pack
Razor42 ( ) posted Mon, 26 September 2016 at 8:32 PM
Your render settings seem fine, the presets should work straight out of the box from what I understand.
Is the scene rendering completely black?
Are you sure your camera view isn't being obstructed by an object in the scene?
Have you checked the DS log file under Help/Troubleshooting after attempting a render? Are there any obvious errors after the render starts?
markht ( ) posted Sun, 02 October 2016 at 6:45 PM
What scene are you rendering?
Older sets made for 3Delight may include a sky dome that blocks the HDRI lighting and will makes the scene render black. You need to delete these skydomes when using the scene with Iray. You can use the HDRI to replace the sky dome.
I have also had cameras inside an object enough that it blocked the Iray render by not the preview render.
