Tue, Jan 21, 4:12 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 21 1:30 pm)
Subject: Poser 11 update
ladydrakana ( ) posted Thu, 12 January 2017 at 4:41 PM · edited Tue, 21 January 2025 at 4:00 PM
Anyone else notice that Smith Micro release an update for Poser 11 yet?
I am downloading right now.
Poser Pro 2010
raven ( ) posted Thu, 12 January 2017 at 5:04 PM
I have found that displacement now renders using GPU in the new update.
ssgbryan ( ) posted Fri, 13 January 2017 at 12:29 AM
Not until you mentioned it.
Downloading now....
ThunderStone ( ) posted Fri, 13 January 2017 at 4:30 AM
Thanks for the heads up.
OS: Windows 11 64-bit
Poser: Poser 11.3 ...... Units: inches or meters depends on mood
Bryce: Bryce Pro 7.1.074
Image Editing: Corel Paintshop Pro
Renderer: Superfly, Firefly
9/11/2001: Never forget...
Smiles are contagious... Pass it on!
Today is the tomorrow you worried about yesterday
vitachick ( ) posted Fri, 13 January 2017 at 6:11 AM · edited Fri, 13 January 2017 at 6:12 AM
Installed update but don't see any change with program loading...Soooooooooooooooooo slow....Update for library loading needs to be worked on.
Win10  Poser 2014/Poser 11 Daz3D
tonyvilters ( ) posted Fri, 13 January 2017 at 7:40 AM · edited Fri, 13 January 2017 at 7:41 AM
Hi vitachick. I have 3 PoserPro11 installations here, and 2 of them open very fast. The third one takes about 5-10 seconds longer for the Library to fill.
Did you try something like cCleaner? Or delete the pref files and let Poser rebuild the set at next start-up? (Make a back-up first)
But Poser rebuilds a fresh preference file set at next start-up if you deleted them. (Or moved them out of the way)
Miss B ( ) posted Fri, 13 January 2017 at 11:56 AM
Thanks for the heads-up. I hadn't heard there was a new update.
_______________
Butterfly Dezignz
EClark1894 ( ) posted Fri, 13 January 2017 at 12:05 PM
What version?
tonyvilters ( ) posted Fri, 13 January 2017 at 2:36 PM
11.0.6.33735 if my memory is not fading yet.
A_Sunbeam ( ) posted Sat, 14 January 2017 at 4:00 AM
Online Now!
On iMac Retina (OS Sierra) the previous version did not function correctly when set to open in full resolution. This version works fine, you can now open Poser11Pro in full resolution.
A_Sunbeam ( ) posted Mon, 16 January 2017 at 3:14 PM
Online Now!
Have noticed sluggish response when selecting from figures list and the appearance of selected item title above its parameter list (also noted in bugs posting).
A_Sunbeam ( ) posted Tue, 17 January 2017 at 2:36 AM
Online Now!
Additional information re sluggish response (also reported in bugs list)💯 There is a problem when selecting body parts - with, say, V4 in the scene and body selected, then selecting 'head' from the body parts list, there is a distinct delay before the word 'head' appears above its parameter list; it used to be almost instantaneous.
Going from 'body' to 'head' for example, this morning, took 3 seconds; from 'head' to 'right collar' needed 7 seconds; adding a jacket and repeating these choices increased some times, the longest delay being 11 seconds. Adding M4, clothed, to the scene also produced delays of over 10 seconds between choosing a body part and the name of that body part appearing above the parameter dials.
This needs to be fixed.
Believable3D ( ) posted Tue, 17 January 2017 at 10:42 PM
Maybe I'll try again. Previous update or two, Poser crashed as soon as I started it, so I had to roll back.
______________
3Dave ( ) posted Wed, 18 January 2017 at 2:49 AM
Thanks, I'll go check it out, if it's newer than my current version, SM will send me a notification in a month or six, they really take care of their Poser customers :(
A_Sunbeam ( ) posted Fri, 20 January 2017 at 5:33 AM
Online Now!
A_Sunbeam posted at 11:32AM Fri, 20 January 2017 - #4295354
Rolled back Poser to SR5 (on external drive) and problem went away. Will continue to test.
