Thanks for the heads up.
OS: Windows 11 64-bit
Poser: Poser 11.3 ...... Units: inches or meters depends on mood
Bryce: Bryce Pro 7.1.074
Image Editing: Corel Paintshop Pro
Renderer: Superfly, Firefly
9/11/2001: Never forget...
Smiles are contagious... Pass it on!
Today is the tomorrow you worried about yesterday
Hi vitachick. I have 3 PoserPro11 installations here, and 2 of them open very fast. The third one takes about 5-10 seconds longer for the Library to fill.
Did you try something like cCleaner? Or delete the pref files and let Poser rebuild the set at next start-up? (Make a back-up first)
But Poser rebuilds a fresh preference file set at next start-up if you deleted them. (Or moved them out of the way)
Thanks for the heads-up. I hadn't heard there was a new update.
_______________
Additional information re sluggish response (also reported in bugs list) There is a problem when selecting body parts - with, say, V4 in the scene and body selected, then selecting 'head' from the body parts list, there is a distinct delay before the word 'head' appears above its parameter list; it used to be almost instantaneous.
Going from 'body' to 'head' for example, this morning, took 3 seconds; from 'head' to 'right collar' needed 7 seconds; adding a jacket and repeating these choices increased some times, the longest delay being 11 seconds. Adding M4, clothed, to the scene also produced delays of over 10 seconds between choosing a body part and the name of that body part appearing above the parameter dials.
This needs to be fixed.
A_Sunbeam posted at 11:32AM Fri, 20 January 2017 - #4295354
Rolled back Poser to SR5 (on external drive) and problem went away. Will continue to test.
Anyone else notice that Smith Micro release an update for Poser 11 yet?
I am downloading right now.
Poser Pro 2010
