Sun, Jan 5, 9:02 AM CST
Subject: Poser 11 update
ladydrakana ( ) posted Thu, 12 January 2017 at 4:41 PM · edited Sun, 05 January 2025 at 7:27 AM
Anyone else notice that Smith Micro release an update for Poser 11 yet?
I am downloading right now.
Poser Pro 2010
raven ( ) posted Thu, 12 January 2017 at 5:04 PM
I have found that displacement now renders using GPU in the new update.
ssgbryan ( ) posted Fri, 13 January 2017 at 12:29 AM
Not until you mentioned it.
Downloading now....
ThunderStone ( ) posted Fri, 13 January 2017 at 4:30 AM
Thanks for the heads up.
OS: Windows 11 64-bit
Poser: Poser 11.3 ...... Units: inches or meters depends on mood
Bryce: Bryce Pro 7.1.074
Image Editing: Corel Paintshop Pro
Renderer: Superfly, Firefly
9/11/2001: Never forget...
Smiles are contagious... Pass it on!
Today is the tomorrow you worried about yesterday
vitachick ( ) posted Fri, 13 January 2017 at 6:11 AM · edited Fri, 13 January 2017 at 6:12 AM
Installed update but don't see any change with program loading...Soooooooooooooooooo slow....Update for library loading needs to be worked on.
Win10  Poser 2014/Poser 11 Daz3D
tonyvilters ( ) posted Fri, 13 January 2017 at 7:40 AM · edited Fri, 13 January 2017 at 7:41 AM
Hi vitachick. I have 3 PoserPro11 installations here, and 2 of them open very fast. The third one takes about 5-10 seconds longer for the Library to fill.
Did you try something like cCleaner? Or delete the pref files and let Poser rebuild the set at next start-up? (Make a back-up first)
But Poser rebuilds a fresh preference file set at next start-up if you deleted them. (Or moved them out of the way)
Miss B ( ) posted Fri, 13 January 2017 at 11:56 AM
Thanks for the heads-up. I hadn't heard there was a new update.
_______________
Butterfly Dezignz
EClark1894 ( ) posted Fri, 13 January 2017 at 12:05 PM
What version?
tonyvilters ( ) posted Fri, 13 January 2017 at 2:36 PM
11.0.6.33735 if my memory is not fading yet.
A_Sunbeam ( ) posted Sat, 14 January 2017 at 4:00 AM
On iMac Retina (OS Sierra) the previous version did not function correctly when set to open in full resolution. This version works fine, you can now open Poser11Pro in full resolution.
A_Sunbeam ( ) posted Mon, 16 January 2017 at 3:14 PM
Have noticed sluggish response when selecting from figures list and the appearance of selected item title above its parameter list (also noted in bugs posting).
A_Sunbeam ( ) posted Tue, 17 January 2017 at 2:36 AM
Additional information re sluggish response (also reported in bugs list)💯 There is a problem when selecting body parts - with, say, V4 in the scene and body selected, then selecting 'head' from the body parts list, there is a distinct delay before the word 'head' appears above its parameter list; it used to be almost instantaneous.
Going from 'body' to 'head' for example, this morning, took 3 seconds; from 'head' to 'right collar' needed 7 seconds; adding a jacket and repeating these choices increased some times, the longest delay being 11 seconds. Adding M4, clothed, to the scene also produced delays of over 10 seconds between choosing a body part and the name of that body part appearing above the parameter dials.
This needs to be fixed.
Believable3D ( ) posted Tue, 17 January 2017 at 10:42 PM
Maybe I'll try again. Previous update or two, Poser crashed as soon as I started it, so I had to roll back.
______________
3Dave ( ) posted Wed, 18 January 2017 at 2:49 AM
Thanks, I'll go check it out, if it's newer than my current version, SM will send me a notification in a month or six, they really take care of their Poser customers :(
A_Sunbeam ( ) posted Fri, 20 January 2017 at 5:33 AM
A_Sunbeam posted at 11:32AM Fri, 20 January 2017 - #4295354
Rolled back Poser to SR5 (on external drive) and problem went away. Will continue to test.
