Sun, Jan 26, 1:49 AM CST
Subject: Ever wonder why...???
Exotica ( ) posted Sat, 13 October 2001 at 3:34 AM ยท edited Sun, 26 January 2025 at 1:46 AM
Ever wonder why you see pics in the gallery (or have some of your own) of headshots where the model has a really big honkin' nose (ie; a terribly distorted face)? That's because the main camera default setting is only 38MM. To avoid this kind of distortion, change the main camera setting to between 75MM & 100MM. Another tip I picked up along the way...to make shadows finer & less jagged edge, change the map size to at least 1024 or higher. Have any tips you want to share? Fell free to post them to this thread.
ScottA ( ) posted Sat, 13 October 2001 at 7:56 AM
Don't eat yellow snow. ;-) ScottA
spothmann ( ) posted Sat, 13 October 2001 at 8:30 AM
...what exactly do you mean by saying "change the map size to at least 1024 or higher"? If you should mean the shadow maps of the different lights in Poser, I have never managed to get them to a higher qualtiy than 1024 - the dials always "jump back" when I try this. You did not mean the shadow maps, did you? Anyway, thanks for the hint with the camera setting :-) Sincerely, Sabine
Exotica ( ) posted Sat, 13 October 2001 at 9:41 AM
hehe Scott - just in time for winter. Spothmann: Not entirely sure but I suspect it has to do with the fact that it may be an infinite light as opposed to a spot. I have the same problem when I use preset lights but don't encounter the problem when I make my own set (I almost exclusively use spots, maybe that's why.) And yes, I was referring to shadow map size. Hope this helps. Pam
mi-scha ( ) posted Sat, 13 October 2001 at 9:44 AM
Doubleclick on the dial for the map size and change the maximum. Afterward you can increase the map size over 1024. Beware: The rendertime and memory consumption of Poser increase also.
jamball77 ( ) posted Sat, 13 October 2001 at 6:44 PM
They are talking about the map of the light. Select your key light and look at the dials there is a dial called map.
Wolfrose ( ) posted Sat, 13 October 2001 at 8:59 PM
I dial up my camera to 180mm
JetM ( ) posted Sun, 14 October 2001 at 1:56 PM
click on the number above the dial for the map. You'll get a mini field where you can type a value for the dial. I use that for dials a lot to be more precise, or if I've got a loooong way to drag (like from 256 to 1024) :)
Nance ( ) posted Sun, 14 October 2001 at 7:38 PM
Try modifying the light's "Shadow Cam" field of view to adjust each light's shadow edge detail (Zoom-In=sharper edges or Zoom-Out=more feathered). As opposed to enlarging the map's size, this method provides better control and can save substantial memory & render time.
