Tue, Jan 7, 9:25 PM CST
Subject: How to get backlit clothing
Renderholic ( ) posted Thu, 16 February 2017 at 2:08 PM · edited Tue, 07 January 2025 at 9:22 PM
I what to create an image with model standing front of a window with her clothing backlit and with a semi-transparent effect. Nothing I have tried looks right. You know the look I am talking about, where the model 's body is stilhouetted through the fabric. I am using Poser 11. Any suggestions on how to get this to look realistic?
ThunderStone ( ) posted Thu, 16 February 2017 at 2:26 PM
What have you tried? Please list them.
OS: Windows 11 64-bit
Poser: Poser 11.3 ...... Units: inches or meters depends on mood
Bryce: Bryce Pro 7.1.074
Image Editing: Corel Paintshop Pro
Renderer: Superfly, Firefly
9/11/2001: Never forget...
Smiles are contagious... Pass it on!
Today is the tomorrow you worried about yesterday
Renderholic ( ) posted Thu, 16 February 2017 at 4:16 PM
I tried adding some transparency at various percentages. That gave too much transparency. Then I tried using a gray texture as a transparency map, but it never looked right either. I wonder if refraction rather than transparency would be better. I'm just not that familiar with setting up material nodes.
bagginsbill ( ) posted Thu, 16 February 2017 at 5:33 PM
Any question about materials for Poser 11 requires that you also tell us whether you want FireFly or SuperFly.
Although they have some common configurations for basics, they're different systems that handle light in different ways and since you're doing a backlighting "trick" it matters.
Renderholic ( ) posted Thu, 16 February 2017 at 9:30 PM
Firefly. I've tried superfly but am not comfortable with it yet.
bagginsbill ( ) posted Fri, 17 February 2017 at 5:45 AM
Assuming your cloth has a simple shader, you can just add a tiny bit of Transparency (.02) and also add a Diffuse node plugged into Translucence. Set the Translucence color and value just like the Diffuse_Color and Diffuse_Value.
bagginsbill ( ) posted Fri, 17 February 2017 at 5:52 AM
If you want a more extreme, stylized effect, set your stage to black and turn off IDL so that no light can bounce and illuminate the front.
Renderholic ( ) posted Fri, 17 February 2017 at 9:06 AM
Thanks! Your first example is more what I am looking for. I will give it a try this weekend. I appreciate your help.
Renderholic ( ) posted Sun, 05 March 2017 at 8:16 PM
I wanted to share the image I came up with using back-lighting. I followed Bagginsbill's suggestions other than having to use a little more transparency. Gallery Image
