Sun, Nov 24, 11:16 PM CST
Subject: can you add inverse kinematics to a figure?
SoulTaker ( ) posted Sat, 11 February 2017 at 12:39 PM ยท edited Sun, 24 November 2024 at 6:34 AM
I have a two legged figure in poser. But it is without inverse kinematics. Can I add it?
PhilC ( ) posted Sat, 11 February 2017 at 2:11 PM
Yes, use the hierarchy editor. Look at the bottom for the "Create IK chain" button. Use the button to create a new chain then drag and drop actors from the list above it to define the chain. I forget if you start with the end of the chain or the root. Try both, one works the other doesn't :)
Boni ( ) posted Sat, 11 February 2017 at 2:17 PM
๐Ÿ‘
Boni
SoulTaker ( ) posted Fri, 17 February 2017 at 3:02 PM
thanks for your help. but sadly it has not turned to be easy. I did say that the figure I was hoping to add it to had two legs, yes this is true. But it is not human, its LG09 combat mach from daz its legs have a few more bit to them. So do not take to adding inverse kinematics. shame. But thanks again for your help
