Sun, Feb 16, 5:26 PM CST
Subject: Lighting setup examples?
Cage ( ) posted Wed, 22 March 2017 at 5:11 PM ยท edited Fri, 14 February 2025 at 8:34 AM
Are there any (fairly current and free) samples of state-of-the-art "realistic" lighting setups for P10 or P11? I'd like to test my frequent use shaders against some "correct" light sets, but all I have are older examples or my own sets, all of which are much brighter than lights are "supposed" to be.
Which is to say, I suck badly at lighting and my shaders are miscalibrated, as a result. I would like to improve, but I can't find any examples to examine. Does anyone know of any?
Cage can be an opinionated jerk who posts without thinking.ย  He apologizes for this.ย  He's honestly not trying to be a turkeyhead.
Cage had some freebies, compatible with Poser 11 and below.ย  His Python scripts were saved at archive.org, along with the rest of the Morphography site, where they were hosted.
Boni ( ) posted Wed, 22 March 2017 at 5:20 PM
Not free and over at DAZ but Jepe's effects has a lightning feature. You may find a feature from the RDNA people that IS free that is a lightning effect there as well. Those are the only ones I am aware of.
Boni
Cage ( ) posted Wed, 22 March 2017 at 6:54 PM
Thanks, Boni. Hmm. I thought RDNA closed down completely? Are they still active somehow?
ghostship2 ( ) posted Wed, 22 March 2017 at 7:26 PM
have you tried my free light set for p11? http://www.sharecg.com/v/86639/browse/11/Poser/Studio-Portrait-Lights-for-Poser-11-Poser-11-Pro
Cage ( ) posted Wed, 22 March 2017 at 8:13 PM
Thanks, ghostship2. That looks like it should be what I need. I'll check it out and see just how bad my shaders really are. I overlight things like crazy, man oh man.
ghostship2 ( ) posted Wed, 22 March 2017 at 8:34 PM
Cage posted at 6:33PM Wed, 22 March 2017 - #4300086
I also have a PBR shader you might want to check out.
http://www.sharecg.com/v/86231/gallery/7/Material-and-Shader/Poser-11-Superfly-Uber-Shader-version-3
Cage ( ) posted Wed, 22 March 2017 at 8:49 PM
Interesting. Is that Superfly-specific, or Firefly-compatible? I'm not using Poser 11 for anything, because it breaks my figures. So I'm not a Superfly user.
ghostship2 ( ) posted Fri, 24 March 2017 at 10:00 AM
Yeah, it's a Cycles/Superfly shader
jura11 ( ) posted Sat, 25 March 2017 at 6:08 PM
Hi there
I would as first use BB EnvSphere and Snarly EZDome which I use in every scene and here are two renders,in first I've used simple 2 infinte lights with low intensity 25-30% and BB EnvSphere,both renders are done in Poser 2014 with FF
Hope this helps
Thanks,Jura
Miss B ( ) posted Sat, 25 March 2017 at 9:17 PM
Ya know Jura, I always marvel at how you get such nice even overall lighting with just 2 infinite lights. I'm curious, where in the scene do you place them?
_______________
Butterfly Dezignz
jura11 ( ) posted Mon, 27 March 2017 at 5:45 PM
Miss B posted at 11:44PM Mon, 27 March 2017 - #4300449
I will try upload my light setup which you can try there
Hope this helps
Thanks,Jura
Miss B ( ) posted Mon, 27 March 2017 at 6:21 PM
Thank you sir, I much appreciate your help. ๐Ÿ˜„
_______________
Butterfly Dezignz
jura11 ( ) posted Mon, 27 March 2017 at 9:04 PM
Miss B posted at 3:03AM Tue, 28 March 2017 - #4300660
Hi Miss B
Here is link on my light setup
https://www.dropbox.com/s/5o2brdj6s951nzq/Runtime.zip?dl=0
If you need HDRi as well please let me know
Thanks,Jura
Miss B ( ) posted Mon, 27 March 2017 at 10:49 PM ยท edited Mon, 27 March 2017 at 10:51 PM
Thank you muchly Jura, I've downloaded it, and will check it out tomorrow.
As far as HDRi's, I've downloaded a dozen or so from the sIBL Archive, and in fact used one of them for the Strolling The Beach render I did recently. Of course, they're mostly outdoor Images, which I suspect is not the type of HDRi you used for the type of renders you posted above.
_______________
Butterfly Dezignz
jura11 ( ) posted Tue, 28 March 2017 at 6:42 AM
Miss B posted at 12:40PM Tue, 28 March 2017 - #4300678
Hi MissB
Please use this one
https://www.dropbox.com/s/qchq0ukttqycrsi/03.zip?dl=0
I've used this one and is my most used HDRi if I do studio renders
if you will need my render settings please let me know there,usually I use D3D script as there I've lot more control
Hope this helps
Thanks,Jura
Miss B ( ) posted Tue, 28 March 2017 at 11:20 AM
Thanks again Jura, and I think I've used his script as well, so will definitely check that out. ๐Ÿ˜ƒ
_______________
Butterfly Dezignz
dlfurman ( ) posted Tue, 28 March 2017 at 4:43 PM
jura11 posted at 5:40PM Tue, 28 March 2017 - #4300658
Hope this helps
Thanks,Jura
Thanks very much.
Now that I have more memory and a Poser SR fixed my Superfly problems, I'm looking check out some of the P11 goodies myself.
