Thanks, Boni. Hmm. I thought RDNA closed down completely? Are they still active somehow?
Cage can be an opinionated jerk who posts without thinking.ย He apologizes for this.ย He's honestly not trying to be a turkeyhead.
Cage had some freebies, compatible with Poser 11 and below.ย His Python scripts were saved at archive.org, along with the rest of the Morphography site, where they were hosted.
Thanks, ghostship2. That looks like it should be what I need. I'll check it out and see just how bad my shaders really are. I overlight things like crazy, man oh man.
Cage posted at 6:33PM Wed, 22 March 2017 - #4300086
I also have a PBR shader you might want to check out.
http://www.sharecg.com/v/86231/gallery/7/Material-and-Shader/Poser-11-Superfly-Uber-Shader-version-3
Interesting. Is that Superfly-specific, or Firefly-compatible? I'm not using Poser 11 for anything, because it breaks my figures. So I'm not a Superfly user.
Hi there
I would as first use BB EnvSphere and Snarly EZDome which I use in every scene and here are two renders,in first I've used simple 2 infinte lights with low intensity 25-30% and BB EnvSphere,both renders are done in Poser 2014 with FF
This with two light setup
This one is with no lights only HDRi map
Hope this helps
Thanks,Jura
Ya know Jura, I always marvel at how you get such nice even overall lighting with just 2 infinite lights. I'm curious, where in the scene do you place them?
_______________
Thank you sir, I much appreciate your help.
_______________
Thank you muchly Jura, I've downloaded it, and will check it out tomorrow.
As far as HDRi's, I've downloaded a dozen or so from the sIBL Archive, and in fact used one of them for the Strolling The Beach render I did recently. Of course, they're mostly outdoor Images, which I suspect is not the type of HDRi you used for the type of renders you posted above.
_______________
Miss B posted at 12:40PM Tue, 28 March 2017 - #4300678
Hi MissB
Please use this one
https://www.dropbox.com/s/qchq0ukttqycrsi/03.zip?dl=0
I've used this one and is my most used HDRi if I do studio renders
if you will need my render settings please let me know there,usually I use D3D script as there I've lot more control
Hope this helps
Thanks,Jura
Thanks again Jura, and I think I've used his script as well, so will definitely check that out.
_______________
jura11 posted at 5:40PM Tue, 28 March 2017 - #4300658
Miss B posted at 11:44PM Mon, 27 March 2017 - #4300449
I will try upload my light setup which you can try there
Hope this helps
Thanks,Jura
Thanks very much.
Now that I have more memory and a Poser SR fixed my Superfly problems, I'm looking check out some of the P11 goodies myself.
Intel Core i7 920, 24GB RAM, GeForce GTX 1050 4GB video, 6TB HDD
space
Are there any (fairly current and free) samples of state-of-the-art "realistic" lighting setups for P10 or P11? I'd like to test my frequent use shaders against some "correct" light sets, but all I have are older examples or my own sets, all of which are much brighter than lights are "supposed" to be.
Which is to say, I suck badly at lighting and my shaders are miscalibrated, as a result. I would like to improve, but I can't find any examples to examine. Does anyone know of any?
